Mervace Working Magnetic motor using induction feedback
Started by Jdo300, November 20, 2006, 01:26:19 AM
mikestocks2006
Quote from: CLaNZeR on November 21, 2006, 01:01:47 PM
Maybe the wire is to just mislead you.
You notice the Magnet on the arm is passing over the Big Capacitor. Anyone popped a meter on a Capacitor and seen if it charges when a magnet is passed over the top?
Sean.
Nice!. I had the exact same thought earlier posted on page 2.
"I wonder if the magnet moving over the charged capacitor is an essential part of the design?...
There is a moving magnetic field moving through an electrostatic field there just before the reed switch discharges the cap over the coil."
Nice to see more members making simmilar observations. Thanks
Vortex1
Adzoe
I see so many questions with this design that I do not understand.  Some have already been discussed in this forum, such as the twisted pair.
Let's look at the other end, the small cap and the resistor.  These are the only connection to the solenoid coil.  That resistor has a value I could not read, perhaps someone else can.  The solenoid seems to be substantially wound, and will therefore have some resistance.  The resistance value of the resistor must be lower than the coil or any charge from the large capacitor would quickly drain through the coil.
The charge from the twisted pair has been shown to be miniscule.  I suspect a far larger voltage and current from the magnet passing the large coil.  This charge will have a polarity and will therefore probably load the small capacitor, possibly even leaking a charge through the resistor to the large capacitor.
As the magnet approaches the coil it should be in attract mode and the small charge in the small capacitor will rapidly dissipate.  Then the passing of the magnet over the coil should induce a charge that might kick the magnet away.
The twisted wire appears to be just for show.
BTW, there are many systems that draw energy from the environment and depend on highly efficient devices.  Some "anniversary" clocks operate on variations in air pressure.  Other similar devices operate on diurnal temperature changes, or even humidity changes.  I once saw a motor, I believe in Popular Science, or perhaps Popular Mechanics, that ran on the potential of a wire suspended from a high flying helium balloon.  If these mechanisms are concealed the device could be thought of as perpetual motion.  Who knows what might be hidden in this Mervace motor.  Time will tell as more information becomes available.
I have encouraged Mervace to loan his device to Sterling Allen or J. L. Naudin for independent research and confirmation.  His current failure to reply to my request or those of others for circuit diagrams and parts specifications causes me a little suspicion.
CLaNZeR
If this is for real then that Cap is getting charged from somewhere to energize the coil to repel the permanent magnet on the revolving Rod.
How that Cap is getting charged is the question?.
Notice how the small cap is angled again in line with the spinning rod at an angle, if it is a Cap?.
Is that a Resistor going to the small Cap or a Choke of some sort?
Why use a resistor in series? what would that gain apart from restricting the current?
Is the coil charging the big Capacitor and then the small capacitor is not a Capacitor but a electro magnet that then repels the rod from the power held in the big Capacitor feeding the coil?
Seems a huge coil to repel a small permanent magnet and also the coil seems on a commercial mount, not a homemade mounting, reminds me of a LNB.
Good food for thought though!!!
Sean.
http://www.overunity.org.uk
hartiberlin
Hmm,
I just tested with my analog multimeter,
if a spiral cable will induce anything as shown,
but my lowest scale on DC voltage has
0.15 Volts full scale,
but there is not even a small movement,
when I waive my strong Neodymn magnets
across the spiral wire.
ALso I tested several caps, if there is any voltage generated at them,
if I waive the Neo magnet across it.
ALso no voltage to see....
So I wonder, if this device is a fake ?
He also did not post any followups...
Yeasterdays reply of the inventor was also deleted , hmm, by him ?
Maybe he has just a hidden 1.5 Volt Battery inside the electrolyte cap case ?
Hmm,
also no new replies from the inventor.
He seems to censor also my other posted comments with this forum link
and my other questions I had tried to post in the comments section there at youtube.
Youtube says, that the comment was posted, but it never showed up.
Maybe some other members can also try to post comments there and see,
if they go through and post the URL to this thread over here,
Many thanks.
Regards, Stefan.
