Thanks to ALL for your help!!
N.R.M.R.E. An investigation.
Started by Grumage, April 11, 2017, 06:43:24 AM
Grumage
Hi Brad.
My apologies, I seem to have removed your image by accident.
This moderator malarkey can be tricky. I was actually trying to resize my own image but hit the wrong box !!
Cheers Grum.
AlienGrey
I thought it was a spectrum analyzer, not to worry though!
Hi all after seeing Tinman's schematic and video (Zephir's mirror Nelson thread), it's the way TK has his transformer wired with the pulsed 250-volt output. Could it be Nelson has one of the 'hot' ends wired to the copper tape on the outside of the plastic coated transformer and using it a radiant energy collector ?????
Regards AG
Nelson did a relay circuit using a two relay osc the first relay was the timer 'on /off' using L and RC thus feeding a second larger coil, got them working great but found it impossible to get Nelsons results with the rest of the circuit.
AG
ramset
Grum
I see it here ,image from TinMan post 130 above
you can remove this post after
Nah. I can do this !!   :)
Thanks Chet.
Thanks Grandma
Grumage
Did you miss something?
Or am I being deluded?
Dog-One
Quote from: Grumage on April 24, 2017, 02:06:17 PM
Quote from: AlienGrey
Hi getting one would be a good Idea or at least a simple one, I'm sure we all know the advantage we could get out of it, they all appear to be around the 1000 mark.  Unless anyone has some ideas ;)
Come on you guys, I know you can figure this out.
When you play with Nelson's circuit, do you not see the similarities?
Raise the voltage and the current goes nearly to zero.  Look familiar?
Why do you suppose it does that?
Let me toss this out there:  The current drops off because all you end up with is tiny little spikes of voltage.
For heaven sakes, this device is a nano pulser.
Now use it to make tiny magnetic impulses instead of voltage pulses, then you can really do something useful.
Can't you see why Nelson didn't need to explain anything further?  He practically spoon feed us as it is.
