N.R.M.R.E. An investigation.
Started by Grumage, April 11, 2017, 06:43:24 AM
Dog-One
I think this quote is relevant to the discussion here, though it was specific to his Radiant Box device.
Quote from: Nelson Rocha
No, I do not charge caps with the output, but I discharge caps to have output :) but that caps first need to be full  :)  is the reason to I say that systems have more that one stage and should not be understood like just one process, but a combination of several process.
Yes, I use nano pulses but made by own design; their action is to create a heavy unipolar pulse that make a very sharp pulse in a coil in a combination of series/parallel resonance. That effect is managed by a parametric oscillator that regulate how stronger is the pulses applied to a coil and the frequency used.  The pulses will increase in their intensity after some seconds system start working and charges start be collected in other stage of circuit, make pulses going stronger and stronger, oscillation after oscillation.
Hope my answers could help you about your doubts
Grumage
itsu
Quote from: Grumage on April 14, 2017, 12:17:21 PM
And finally..... A big thank you to Itsu.... My first post with individual quotes.....
Cheers Graham.
Way to go Graham, your answers to questions now leave no room for confusion.
TK,
i think you pretty well summed up the present state of this circuit.
My hope was that Nelson would chime in here, but appearently he does not.
Concerning the "hypothesis under test", what about: trying to determine once and for all what this "HV radiant" is, and if it exists at all.
How it manifests, how it smells and looks like etc.,  many OU researchers would be very pleased to finally know.
I was hooked when i saw that Grumage his setup kept on running for severall minutes, something that i could not replicate.
Itsu
Dog-One
Quote from: itsu on April 14, 2017, 03:33:34 PM
Nelson has a big project and demonstration for his employers due in August.  I wouldn't expect him to have all that much spare time.
Answers to the $64,000 question already?
One step at a time.
Change, Divergence and Curl.  Master those concepts and any limitations you currently have will be eliminated.   ;)
itsu
QuoteChange, Divergence and Curl.  Master those concepts and any limitations you currently have will be eliminated.   ;)
Wise words Dog-one,   you should change your handle to Grasshopper  ;)
Itsu
