Some Bifilar coil experiments
Started by evostars, April 11, 2017, 04:31:06 PM
evostars
I thought about how to extract energy from a high voltage system. As that is a tricky thing. It all needs to be tuned. In the attached drawing I used 2 pulse transformer, to generate AC on the secondary.
Don't know if this would work, but it would be a way to transform the high voltage into low voltage, high current.
The spark gap, would also be part of the system, I believe it should be in the center of the bifilar coils, as that would return some of the spark energy back into the system.
Zephir
You can draw the load from resonance circuits in many ways, but these usually don't involve the overunity. This is where the bifilar coil comes by: it draws the current without inducing the back electromotive force into an circuit.
dieter
@evostars, of course, I just read the wrong line. We had the same results, I approximated adhoc to 64mJ, you said 65mJ.
However, Voltage alone is nothing. V*A=W. V*V=0...
still, wish you success.
evostars
Quote from: dieter on April 14, 2017, 05:23:22 PM
I didn't say 65mJ i said 0,65J that equals to 650mJ (m=1/1000).
Thank you for wishing me success.
Success to you too.
evostars
screenshot of the relation between the pulses of the center coil,  and the resonant sine wave of the reversed south coil
