Some Bifilar coil experiments
Started by evostars, April 11, 2017, 04:31:06 PM
evostars
@ zephir
it is indeed possible to make these magnetic fields that are opposite.  but that way of connecting is not what im interested in, nor was it stated in tesla's patent. although his patent seems to be stripped of alot of additional information.
I feel its unnatural to counteract the magnetic fields. although its interesting, I have choosen (for now) to not investigate this way of connecting the bifilar coils.
the dielectric field also is differently between the windings.  the input and the output will have the biggest voltage difference, while the center where the coils connect,  there is no voltage difference.
interesting, but not for me.
I keep working with the coil as discribed in the patent. I request you kindly to proceed with this offtopic different coil at another topic lead.
Zephir
The simplest experiment how to demonstrate the existence of scalar waves violating the classical physics is the attempt for their transmission at distance. The scalar waves aren't absorbed with metals, so that the metal sheets (Faraday cage) can be used for their separation and "purification" from superposed classical, i.e. transverse electromagnetic waves. We can utilize pair of bifilar coils for it, which we separate with grounded Faraday cages or even better with ferromagnetic sheets. Under laws if classical physics no signal should be transferred from generator to detector coil at distance, especially not when the coils will be separated with metal sheet.
The analogous experiment with scalar wave transmission we can arrange with pairs of capacitor, which must be planar (i.e. not rolled - typically high quality mica capacitor), which will be charged into high voltage (the higher the better). If we would load one of capacitors with DC signal, then the another capacitor will detect it at distance. In this situation you'll reveal, that scalar waves have pronouncedly directional character - they're not spreading through vacuum in spherical waves like normal EM wave - but like the superluminal beam. The detection of signal from first capacitor with another one will strongly depend on their mutual orientation. And again: the surrounding of capacitors with conductive shield (Faraday cage) shouldn't affect the scalar wave transmission.
Zephir
Quoteit is indeed possible to make these magnetic fields that are opposite.  but that way of connecting is not what im interested in
LOL - and which way of connecting are you interested about? In bifilar coil the magnetic field always have opposite orientation.
evostars
Quote from: Erfinder on April 16, 2017, 01:40:59 PM
I am not here to convince you of anything....I am sharing my experience.  I have issues with many things you have stated above, however, I will keep these things to myself  as they will not be accepted anyway...folk must find their own way.
Good luck with your research.
thank you for letting me find my own way. good  luck to you too
evostars
Quote from: Zephir on April 16, 2017, 01:35:48 PM
the other way: coilwinding1 outside to inside. coilwinding 2 inside to outside series connected.
In this way the magnetic field of the 2 coil windings produce a magnetic field that cancelles out between the windings.
this is not my way
