Some Bifilar coil experiments
Started by evostars, April 11, 2017, 04:31:06 PM
dieter
I didn't "suggest 50 or 60 hz"), I asked "40 - 50 kHz?"
I tried to explain to you that you can use a high ohm resistor, as high as it has to be so it won't pevent the effect, use a megaohm if you like, you can still do the calculation of Watts.
Of course you need to find the resonant frequency for a certain fixed Load, while it is connected!
However, if you are unwilling or unable to actually read my text ( let alone not treating me like a stupid little boy) then this was certainly my last attempt to offer help.
Excuse me for scratching your crown.
evostars
Quote from: dieter on April 16, 2017, 10:34:39 PM
50-60hz or khz doesn't matter.  It can work,  as long if it is the resonant  frequency of the top and  bottom coils.(that's what i meant before) my coils don't reach that low.
evostars
on a personal note: I must admit, I feel very misunderstood. And sometimes I put on my crown.  I can react hard and close minded, because i feel so misunderstood and cast out.
I'm only human.
this is my responsibility.
Im working on this
Magluvin
Quote from: Zephir on April 16, 2017, 12:39:44 PM
The bifilar coil (there are many of them) has some inductance and capacitance common with classical coils and capacitors, but these properties are parasitic only. Primarily it's the scalar field/wave generator/receptor. Inside the normal coil magnetic fields are additive, inside the bifilar coils they're acting against each other, i.e. they're producing compression waves, not these transverse shear ones.
The difference between wires of normal coil and bifilar one is similar like the difference between paddles forming surface and underwater sound waves at the water surface. The paddles create mostly surface waves, so that they must operate in unison like the wires passed with current within normal coil. For creation of the underwater waves we must compress and expand water surface periodically, therefore our paddles must move against each other. The formation of surface ripples and their spreading into outside is undesirable secondary effect in fact. The ideal bifilar coil is supposed to spread only scalar waves, not EM waves into outside.
The bifilar coil therefore forms a lattice of magnetic field which are oriented against each other like the magnets which are glued together in repulsive arrangement. Now we can put the principal question: does the property of vacuum change when we have two strong magnets, which act against each other in such a way, their effects are nullified? From perspective of classical Maxwell theory there is no difference between empty vacuum without any magnetic field and vacuum in which strong magnetic field compensate mutually.
From perspective of dense aether model such a fields indeed differ because such a vacuum is rich of energy (the repulsive magnets can do a work) and we have analogy for it in dielectric field of charged capacitor. The vacuum between plates of charged capacitor gets polarized and its plates attract or repulse itself in similar way, like the magnet in attractive or repulsive arrangement. The capacitors charged to a high voltage therefore can serve as a generators and/or detectors of scalar waves in similar way, like the bifilar coils.
Are you talking about a series bifi coil as shown with connections as Tesla has shown in his pat for Electromagnets? Or are you talking about reversing one of the filar conductors connections so as its currents are flowing in the opposite direction of the other?
Otherwise how is it the magnetic relationship between adjacent turns change with a bifi coil vs a normal coil of the same dimensions as you have described?
Mags
dieter
I was in a bad mood when I wrote that, psl excuse me.
I don't believe in "there is no free lunch" and the invincibility of the law of energy conservation, so I guess we're on the same side.
kr
