Some Bifilar coil experiments
Started by evostars, April 11, 2017, 04:31:06 PM
PolaczekCebulaczek
I think that we no longer have spinning electric fields, when both E fields oppose each other they become negative electrostatic field(s) so maybe this negative electrostatic field is interacting with secondary winding neutral wire by pushing electrons upward, this is some strange vibration because meter register 0 voltage or current.
Belfior
Jack Noskills' document describes this. He states that the 2 wires are charged with like charge (similar). He says only coulomb's law applies.
Jeg
Quote from: PolaczekCebulaczek on December 13, 2017, 01:20:40 AM
..... so maybe this negative electrostatic field is interacting with secondary winding neutral wire by pushing electrons upward, this is some strange vibration because meter register 0 voltage or current.
We have two wires the one next to the other. If current would go on the same direction to both of the turns (tesla bifilar)  then we have the right conditions to form a capacity and to store charges in between the turns. If current goes like in your drawing then it is like we push a positive current to both of a cap's legs. Perhaps in this situation, displacement current changes also direction and so it charges the dielectric between primary and secondary. Just an assumption though which needs experimentation.
Belfior
I have made coils like Jack Noskills' document says, but I can continue testing them in January
He has pretty extensive tests conducted in his documentation. I have witnessed some effects, but not to the extent he is claiming. I suspect he has ferroresonance
PolaczekCebulaczek
