Witness the Free Energy effect
Started by Theoretical Research, April 16, 2017, 05:16:47 PM
Lorentz force is as it says, a force. It can push against or toward the flow of current. It can have both, resulting in no net loss as in the case of the ideal inductor.
The majority of the magnetic field from conventional powerful magnets is caused by electron intrinsic spin, which also produces a vortex of space flow. The size of the magnet plays a noticeable role in the velocity of the space flow, which is why the space flow around Earth is significant. It's possible to achieve comparable velocities with magnets, but it's a bit more complicated, sometimes resulting in unpredictable experiments due to the inertia required to build up a substantial velocity, location, and the properties of material that space is flowing through. I'm told that location can be one of the most important factors in this technology for the leading edge researcher who will give this technology to humanity.
Kator01
TR,
you have asked for a simple method of measuring rf-currents. This can be done by measuring rf- voltage across a 50 Ohm dummy-load with successive rectification, see here
https://www.nonstopsystems.com/radio/frank_radio_antenna_power-probe.htm
dummy-load left to the BNC is not shown. The rf is fed to the 50 Ohm dummy and the voltage-drop across it fed into the BNC
The most common germanim diode you can get is this here : AA143
https://www.rf-microwave.com/datasheets/5992_Microsemi_AA143_01.pdf
Hope this will help you
wish you success
Mike
Edit: concerning the 50 Ohm-dummy resistor: you need a  rf-resistor-type since standart-resitors distort the resulting voltage by
their inner inductance. Chip-resistor would be the best choice
http://uk.farnell.com/c/passive-components/resistors-fixed-value/rf-resistors?DM_PersistentCookieCreated=true
Quote from: Kator01 on November 20, 2017, 01:24:27 PM
TR,
wish you success
Mike
Thanks, I was going to build the mixer circuit that looks at the the capacitor anomalous voltage, but I decided it might be a bit too much headache for replicators. Diode would be easier, but at these voltage levels it's based on the square law, which means the scope would have a lot of problem seeing it. There's another idea that requires nothing but an oscilloscope, signal generator, copper wire & foil. :)
