Witness the Free Energy effect
Started by Theoretical Research, April 16, 2017, 05:16:47 PM
Quote from: Zephir on April 21, 2017, 12:22:36 AM
Hi, Theoretical Research,
thank You for your attention and kind support...:-) I'll check the Spice file for sure.
What do you say about my proposal for elimination of the stray capacitance by separation of coil and capacitor with shielding? Will the effect still persist in your device? It should..
If you're talking about putting metal in the inner part of the core, then that will reduce the EGS effect. It causes an increase in capacitance, which acts to cancel the inner core charge during each cycle.
We can use the scope channel 2 as a means to cancel the signal.
Or better yet the digital version which uses a pulse which causes a LR decay which a cmos switch passes a section to an op-amp thus producing a DC output with low pass filter.
Quote from: vasik041 on April 21, 2017, 07:22:06 AM
Hi Theoretical Research,
It would be nice if you can draw simple diagram to illustrate your setup.
I still not sure what you propose to test.
It's difficult to show the physical construction in a spice diagram. I drew a quick crude drawing with my tablet & pen. See attached image. I could dismantle my setup and record a video of the core, but youtube has always destroyed the video quality making it difficult to see individual components.
The scope probe channel 1 is connected to the 10 ohm resistor. Channel 2 is connect to the signal gen. The black cable in the drawing is connected to the signal gen.
The drawing shows 3 turns, but I would recommend 10 turns.
The orange areas are copper foil.
The yellow area is balsa wood or plastic. There are two sheets of balsa / plastic-- inner and outer. The drawing only shows outer. The balsa / plastic goes on the round part of the core. Actually the outer part should be plastic since it does not need to reduce the dielectric. The inner part can be balsa or plastic.
R_bottom is a 2K resistor connected to the inner copper foil, the bottom part of the core. R_top is a 2K resistor connected to the inner copper foil, the top part of the core. Both R_bottom and R_top are connected to the coax cable.
R5 is a resistor connected to the outer part of the cores copper foil. R5 is connected to the coax cable ground.
The entire outer part of the core is wrapped in copper foil, one layer. Same goes for inner core.
Zephir
Hi, TR and than you very much for clarification of another details, which indeed explained a lot. No video is actually necessary, the scheme is OK and I can redraw it in some SW later.
But couldn't the copper foil be just omitted at the place of coil? It would eliminate some stray currents induced into the coil from copper foil. It could be also surrounded/underlayed with stripe of grounded sparse mesh or conductive pasta for shielding from the rest of ferrite, as Vertex1 is proposing...
And why the 2K resistors R_top, R_bottom and R4 resistors were used - for impedance match, protection of generator from short or something else? Why the device isn't grounded (i.e. connected to ground of generator cable) directly? With floating ground your device will be intensive source of radiation even at the 900 kHz / 20V and you could detect stray voltages at all places of it. You would measure some signal everywhere in this arrangement: the presence of stray voltage will not be evidence of anything specific, overunity the less.
In the drawing and ltspice file the outer copper foil is connected the coax ground.
In real life experiments I could place the device 1/2 inch away from my hands or body without any noticeable change in output. It was unaffected by electronic devices, tvs, etc. due to the 10 ohm resistor.
vasik041
thank you for detailed drawing and explanations.
