Witness the Free Energy effect
Started by Theoretical Research, April 16, 2017, 05:16:47 PM
vasik041
Quote from: Theoretical Research on April 22, 2017, 02:07:48 PM
Someone was asking why there are so many self runners in Russia.
Don't be naive, most of them fakes or 1st April jokes  ;)
partzman
For those interested, I have had positive bench results testing TR's EGS effect that may be seen on OURdotcom on the "Theoretical Research Device" thread.  You do not need to be a member to view the contents of the thread but do if you wish to post.  The results agree closely with the simulation of the core assembly which is a ferrite TV yoke with copper foils and a 10 turn sense coil.
Regards,
PM
vasik041
Quote from: partzman on April 23, 2017, 10:00:13 AM
Regards,
PM
Hi Partzman,
Thanks for posting this.
To make sure that effect is "real" I would suggest you trying change polarity of signal generator and repeat the experiment.
Then change polarity of the sense coil and again repeat experiment.
This way you easily see how ground connections (and other stray capacitances) affect your measurements.
Regards,
V.
partzman
Quote from: vasik041 on April 23, 2017, 11:31:46 AM
Hi Partzman,
Regards,
V.
V.,
You're welcome.  You have a good suggestion that I will try as there are many more tests planned to both confirm and improve the outcome.  We hope TR will release some test info on the air core design as it seems difficult to find suitable ferrite cores that meet his requirements for successful replication.
Regards,
PM
Regards,
PM
Awesome! I've had relatively stable results with the first core I used, although it did fluctuate a bit, but the overall voltage was close to my spice sim. Hopefully your tv yoke core will be stable as well. Although you'll probably see the fluctuations over time, but get a good idea of what the average signal is when rotating the core with respect to earth's surface. My flyback core though, wow, it's an amazing core for a self runner with respect that it has incredibly low non-conductive R, but what I'm seeing so far is that it is extremely unstable. Yesterday it appears the flyback core's non-conductive R was through the roof (high). It will be interesting to see what type of hysteresis loop it has (square loop, flat ...). I do not believe the instability of the flyback is do to the fact that the core is split. I've tested this core's non-conductive R with and without the plastic spacers. The R decreased a bit with the spacers, as expected. What I saw yesterday was abnormally high non-conductive R. So much that I could barely see a slight resonance hump in a frequency sweep. Furthermore, after turning the equipment off for about a half hour and going back to the experiment, the flyback performed beautifully again, but that lasted a few minutes. Right before my eyes I saw the core change characteristics.
Good news is that it appears tv yokes are a great choice. They have low inductance, but due to their wide surface area they offer significant increase in capacitance for the copper foil. :)
