Thanks to ALL for your help!!
Witness the Free Energy effect
Started by Theoretical Research, April 16, 2017, 05:16:47 PM
PolaczekCebulaczek
Quotebut get a good idea of what the average signal is when rotating the core with respect to earth's surface
Wait,  what?? so if someone here can demonstrate a power change when device is oriented at different angles with respect to earth (just like in S.Mark, Hendershot devices) than this would be a huge breakthrough, a something really SPECIAL.
Quote from: PolaczekCebulaczek on April 23, 2017, 05:12:41 PM
It's true. I just finished testing a new design, tamed down version, that produces a change of about one tenth of a volt (no amplification needed) by physically flipping the device. That was the predicted voltage according to a LTspice sim using my best spice model of the Metglas 3210P4AF magnetic core. The untamed version should produce close to one volt. This is the 3rd version. The 1st version that I've called the digital pulsed version worked every time, but required an amp gain of 10,000. The 2nd version that I've called the single frequency version worked on rare occasion, and also required high amp gain to see the voltage change. I now know exactly why the 2nd version is a bad design. The 3rd version that I finished today works every time, and doesn't require an amplification. I should add that LTspice correctly predicts the 2nd version experiments as well.
This device was secured to a long plastic pole, about 7 feet long, and placed about 6 feet above ground. The long pole is placed horizontally parallel to Earth's ground, and then rotated so that the core flips between facing toward Earth, and away from Earth. This allowed me to rotate the device by rotating the end of the pole. In one position the device is facing down. The other position the device is facing up.
See the attached photos. The circuit is blacked out until I learn it's okay to release this technology because this design is too close to a self runner. I was advised to release this technology in 2020. Possibly sooner. Please don't ask why!
Metglas cores are not a good choice for self runners. It's best to use extremely efficient cores, cores that have extremely high resistivity, e.g., 2e+8 ohm·cm, low magnetic viscosity, and as high permeability as possible, but permeability is not as important.
I'm told by a source that I trust 100% that the effect is not due to space accelerating to Earth, but is caused by a spinning vortex of space that *tends* to follow the magnetic field, but not exactly. Therefore, in theory I would expect the polarity of this device to flip if I were to cross the Earth's equator. Similarly, I would expect the effect to intensify as one approaches the north and south poles, e.g., countries such as Russia. Hint, hint. ;)
I'm also told that magnetic materials also produce the space vortex, but the magnetic field intensity is not the only factor. I believe the space flow velocity is relative to sqrt(diameter) * B. Earth's magnetic field is weak, but the planet is large. So it's possible to make a self-runner that's independent of Earth's space vortex.
This technology is about producing an intense magnetic field within a perpendicular electric field within perpendicular space flow. The E-field does not have to come from a conventional capacitor, e.g., two metal plates. Wires around a coil also produce E-fields (V/m). Wires in a coil can produce tens of 1000s of volts. When you an intense B-field perpendicular within an intense E-field, both within an intense space vortex that is perpendicular to both the B-field and E-field, you cause a force that either pushes against or with the space flow. If the device is pushing against the space flow, you get free energy. If it's pushing in the same direction as the space flow, you lose energy.
Last, the weight of the devices that tap into Earth's space vortex can change by a noticeable amount in high power devices.
[edit: uploading a smaller image]
ramset
Trying to shrink your text so it can be read ,your image above needs to be resized so we can read the page  [to big]**
REPOST BELOW OF TEXT
PolaczekCebulaczek
end quote
you lose energy.
Thanks Grandma
Is there a way to turn it into a thumbnail image that's clickable?
Regarding personal messages to build a device to witness the free energy, and anyone who's interested. Here are the 3 options:
The Red pill
The only way I'll help people from this point forward is to use exact part numbers for key components such as the magnetic core, MOSFET, and timer chip. That means you'll need to buy a core from Amidon. If enough people agree to replicate this, then I'll come up with a design that demonstrates the space flow effect without making it too obvious how to make a self runner.
The Blue pill
Do nothing, and just wait till humanity is ready and responsible enough for this technology, which will indeed eventually allow any individual on Earth to literally destroy the entire planet. No reply necessary.
The Purple pill
Have a well known and trustworthy person from OU meet me at some location out here near LAX where they will have full access to a device that will demonstrate the space flow effect. That way nobody has to build anything. This person has the option of bringing the amidon core (wound) and whatever other parts they wish so that they can drop it in the device.
