Witness the Free Energy effect
Started by Theoretical Research, April 16, 2017, 05:16:47 PM
ramset
Clickable image might be something we can ask Stefan about ?
this image size issue has been a thorn over here for a long time [easy to do accidentally]
on the other topic?
we do have a few very trusted friends on your coast who might be able to help with  this ?
one in particular [Smokey 2]
I haven't spoken to in quite some time ,a very cool fellow who recently relocated out there.
I'll ring him today for sure.
respectfully
Chet K
Thanks Grandma
kampen
Dear, please count me in for the RED pill.
FatBird
Theoretical Research mentioned rotating magnetic fields.  Click on
the Link below to see how a North Pole rotates it CW & a South
Pole rotates it CCW.
https://www.youtube.com/watch?v=afQW8FT02DM
PolaczekCebulaczek
Quote from: Theoretical Research on October 26, 2017, 09:57:28 PM
It's true. I just finished testing a new design, tamed down version, that produces a change of about one tenth of a volt (no amplification needed) by physically flipping the device. That was the predicted voltage according to a LTspice sim using my best spice model of the Metglas 3210P4AF magnetic core. The untamed version should produce close to one volt. This is the 3rd version. The 1st version that I've called the digital pulsed version worked every time, but required an amp gain of 10,000. The 2nd version that I've called the single frequency version worked on rare occasion, and also required high amp gain to see the voltage change. I now know exactly why the 2nd version is a bad design. The 3rd version that I finished today works every time, and doesn't require an amplification. I should add that LTspice correctly predicts the 2nd version experiments as well.
This device was secured to a long plastic pole, about 7 feet long, and placed about 6 feet above ground. The long pole is placed horizontally parallel to Earth's ground, and then rotated so that the core flips between facing toward Earth, and away from Earth. This allowed me to rotate the device by rotating the end of the pole. In one position the device is facing down. The other position the device is facing up.
See the attached photos. The circuit is blacked out until I learn it's okay to release this technology because this design is too close to a self runner. I was advised to release this technology in 2020. Possibly sooner. Please don't ask why!
Metglas cores are not a good choice for self runners. It's best to use extremely efficient cores, cores that have extremely high resistivity, e.g., 2e+8 ohm·cm, low magnetic viscosity, and as high permeability as possible, but permeability is not as important.
I'm told by a source that I trust 100% that the effect is not due to space accelerating to Earth, but is caused by a spinning vortex of space that *tends* to follow the magnetic field, but not exactly. Therefore, in theory I would expect the polarity of this device to flip if I were to cross the Earth's equator. Similarly, I would expect the effect to intensify as one approaches the north and south poles, e.g., countries such as Russia. Hint, hint. ;)
I'm also told that magnetic materials also produce the space vortex, but the magnetic field intensity is not the only factor. I believe the space flow velocity is relative to sqrt(diameter) * B. Earth's magnetic field is weak, but the planet is large. So it's possible to make a self-runner that's independent of Earth's space vortex.
This technology is about producing an intense magnetic field within a perpendicular electric field within perpendicular space flow. The E-field does not have to come from a conventional capacitor, e.g., two metal plates. Wires around a coil also produce E-fields (V/m). Wires in a coil can produce tens of 1000s of volts. When you an intense B-field perpendicular within an intense E-field, both within an intense space vortex that is perpendicular to both the B-field and E-field, you cause a force that either pushes against or with the space flow. If the device is pushing against the space flow, you get free energy. If it's pushing in the same direction as the space flow, you lose energy.
Last, the weight of the devices that tap into Earth's space vortex can change by a noticeable amount in high power devices.
[edit: uploading a smaller image]
Theoretical Research, there is a SOLID theory behind your device, not some bullshit about energy from nothing however, we must remember that by taking energy from something that is moving we would slow down its movement so in your case... can you slow down the cosmic wheelwork of nature? I'm extremely exited about this technology, in fact, once I was thinking about building something similar but I gave up because "if it were so simple than such generator would be invented and distributed long time ago". PLEASE can you make a video of the effect?  (1 volt changing without any amplifier due to change of device position)
also, IF I shoot a charged HV capacitor from cannon and if this cap flies through a coil, would any current be induced?
Quote from: PolaczekCebulaczek on October 27, 2017, 07:58:30 PM
Interesting questions. It's true that the math comes from classical mechanics. The unknown is the planet's vortex of space flow.
I'm told that when such a device takes energy from the planets vortex that a cloud of fine particles can form around the device, and thus the planet would actually gain mass. This Earth's magnetic field is not affected. The energy comes from what mainstream knows as the vacuum. I would like to add my personal observations. The first time I saw such a high power device I panicked because I swear there was faint smoke coming from the device. I thought my MOSFET was burning up. I see this faint smoke effect every time when the device is powered on. I don't know how I can see this faint smoke, but have often wondered if other people would see it. It's a mystery. Maybe it's just a psychological effect? Idk. Has anyone ever noticed something like that?
