Dr Ronald Stiffler SEC technology
Started by antimony, April 25, 2017, 09:09:27 AM
NickZ
   OK, I'll make them smaller yet, like 800 wide, or so.   We need to keep the site working right.   Thanks.
   BTW:  I can't read the numbers on the crystal, I can see three zereos, 000, at the end, first number has solder on it.
  I an still tryng to find the right bulb with the metal backing, otherwise it won't work, capacitively.I see that building the correct controllable crystal, or other, type of oscillator circuit is essential, as most guys don't have an SG.
  My idea is still to follow the capacitive trail to the source of any anomoly.
Slider2732
Likely a lot of this is about the monitors used.
For example, mine was from a Salvation Army thrift store for $5...IBM ThinkVision 17".
It's square. Many others will have 24" super wides or 3 monitors in a horizontal line and all
that snazzy stuff. Somewhere between will be widescreen laptops and likely phones and tablets.
Browsers will also display differently. Am using Firefox 59.0.2, where 1000px is a touch
wide here too.
The ideal would likely be an image that can be seen, say 640x480 and which would suit all
scenarios, but that can be clicked on for a full sized version.
Am soldering up the AD9850 signal generator today.
The rotary encoder and screen are still on their way, but another encoder has been finally
found and a 1602 screen has been removed from a previous project.
The idea is to run a frequency, any frequency up to 30MHz with the circuit and then see
how simplified circuits such as the tunable exciter setup behave with that same frequency.
The AD9850 is a low output device, but will help with verifications and pointers for
resonant frequencies of coils and loads.
gyulasun
Quote from: NickZ on June 18, 2018, 11:13:19 AM
I think Slider posted a link to a good crystal checker and if your crystal oscillates then you can estimate the frequency
from the scope display. See the circuit you could buld with any small signal transistor:
http://jaunty-electronics.com/blog/2012/08/simple-oscillator-as-crystal-tester/
On the scope you extend the time base to see say 2 full period of the waveform, it makes easier to see and calculate frequency.
Gyula
Lidmotor
Gyula---Thanks for the help on the post size.  I still don't quite understand what is going on. I changed to another computer and on this computer the text at least is the right size.  Can it be a basic setting on the other computer?  I'm very sorry about the oversized posts with the BIG picture.  I will work on this and not post pics until I have the problem solved.  Using paint on the computer will work on the pics but what about the text width?
Thanks,  Lidmotor
P.S. All --  I think this project river is flowing in the right direction even though there are side eddies.  I am anxious to see Slider get his homemade frequency generator up and running.
Here is a test picture from this computer--
SkyWatcher123
Hi all, Hi gyulasun, thanks for the information.
Yes, that is exactly what i was thinking to try next, is multistrand 24awg. magnet wire primary coil.
I'll try a bifilar 24awg. magnet wire coil with both strands in parallel and use 80 turns again.
The coil will have even more mass now, we shall see how she performs.
peace love light :)
Edit: ok, i just finished winding the new magnet wire coil, it is bifilar 24awg. magnet wire, strands are in parallel at 300 milliohms and 31 grams weight, which includes a little electrical tape, that is used to tighten the windings together.
