Dr Ronald Stiffler SEC technology
Started by antimony, April 25, 2017, 09:09:27 AM
hartiberlin
In Dr. Stifflers last video: SMF understandig?...
https://www.youtube.com/watch?v=FFhRx8PgK8c
just see, that the bigger his metal on the backside of the Cree panel is, the better the light output....
that really confirms, that it is the bigger capacitance letting more RF curent flow going back via the air to his function generator...more picofarads lets more RF current flow...
now the question still is, how high the voltage output of the RF generator really is and how high the voltage is after the L3 going into the magnet...
As he has lots of good measurement equipment he really should do these measurements to see,
what is really going on or use a battery powered RF oscillator to feed the circuit and then compare
the input power from the battery with the light output at the Cree...
Many thanks.
Regards, Stefan.
hartiberlin
Dr. Stiffler should put his HP Signal generator onto a watts meter and show the input power into it 2 times,1. when he has the signal generator running at the same frequency without connecting his SFM circuit ( LEDs not lighting)2. Connected to his SFM circuit and the LED shinning brightly...
Now in the second case is the input power into his signal generator about 1 to 2 Watts higher ?
If yes, we know, that the power just comes from the grid...
ramset
Dr.Stiffler says he carried the secret long enuff??
He calls it
"The Diode Loop"
or Stiffler Loop
https://www.youtube.com/watch?v=XhdfwmeWevs&feature=youtu.be
Thanks Grandma
NickZ
  Before Doc needed to use a ground line to connect his psec circuit to the house AC ground. Which we know to have an influence from stray capacitance from the AC grid source. He would not take his circuit and test it outside, just using an earth ground connection. He was very stubborn about this.
  And now after all these years he still needs to connect his circuit to something, for it to dimly and partially light the cree board. Not very impressive, nor useful, that I can see.
   I was hoping to see better results, by now. Sorry, but it's not very convincing the way he's showing it.And I really doubt that will he take any advice or suggestions from Stefan.
  In any case, it's good to see him at it still.
Belfior
Quote from: NickZ on May 28, 2018, 11:43:02 PM
Yes I can understand that people want evidence that supports their own theory, but refusing any critisism and not taking the device outside to earth ground means that he is using his grid in some way. I mean is your goal to cheat yourself, the electric company or to find OU?
Light up a bulb and self-loop it. That is my answer to myself. I don't even like using batteries, since that always brings in more questions like "this seems OU, but is it because you are destroying the battery?"
