Dr Ronald Stiffler SEC technology
Started by antimony, April 25, 2017, 09:09:27 AM
NickZ
   Slider:   You mentioned: "I think the point of these latest experiments is to run a bulb from far less power input than would regularly be used. Plus by the very nature of resonance, every bulb would be dimmable".        end quote.
    Well, that may be part of it, but I think that another part of the goal is to understand where any extra energy is coming from, if such exists, what is it, and just how to best tap into it.
   As you may know, there is no way to currently test for Aether sources. So, it's a tough call... we can only test for its "effects".
ramset
I know Nick can't post the Stiffler links from his I phone / Cup and string.....
so here are some links
Today   https://www.youtube.com/watch?v=On_ynVaUGHM
2 days ago  https://www.youtube.com/watch?v=mkuvHgCmm6U
3 days ago  https://www.youtube.com/watch?v=2Z9ae0MkfbQ
Chet K
Thanks Grandma
NickZ
deslomeslager
Ronald did not see my second comment on YT. In reply to my first comment he clearly stated 27 mc is not okay. So here is my 2 cents for a better solution:
Google for "NFC Reader writer USB RFID 13.56 Mhz"
It usually is USB powered so the voltage will be low. Far from 20 Volts peak to peak. Perhaps it is closer to 2 Volts peak to peak.
Perhaps we have a developer in the house with an RFID reader?
If not, take your SFC apparatus to the store and try it there :-) It won't harm their equipment.
I don't have one, all I have is a 20 Mhz sinus generator max. 1 Volt peak to peak :-(
Of course I did not even try it out. (it runs over USB on a windows 95 program, old stuff).
gyulasun
Hi Nick,
I think the answer to Dr Stiffler's  'which is which question'  is: the current loop is into which the single super bright LED is embedded and the Cree LED board on the lower left is fed by the 'standing waves'.
If you have a certain size of enamelled copper wire between say awg 24 to 33, you could make a single layer air coil on a PVC pipe of say 3 to 4 cm OD and say with 20-25 cm length then you could wind a coil which very likely has an SRF of less than 2 MHz your generator already works.
I used coil32 free coil calculator see here http://coil32.net/  and I estimated the above and below data by that.
On a 3 cm OD, 25 cm long PVC pipe a coil with 610 turns from d=0.32 mm enamelled copper wire gives an SRF of  1.979 MHz and this self resonant frequency would be less than that when you connect the coil into the Dr Stiffler circuit.  Winding length would be about 19.5 cm when using the 0.32 mm wire.  If you have other sizes for the pipe or wire, the calculator estimates the data.
Gyula
Quote from: NickZ on June 03, 2018, 03:12:41 PMStanding waves, or the Stiffler loop. "Which is it".  Both, perhaps.
   Guys:
   Watch the Docs latest video, posted today, about that.   I think that I know where he's going with all this, but he's still a ways away.
These last few videos are just more tests to see what up with that.
   I would like to tag along, but don't have the high end SG.
   However, I do have a working Kacher circuit, able to output about 5000v, or higher. As well as a 2Mhz signal generator, that's just collecting dust. I don't know if any of that would really do, here.
   We need to know the exact turn count on his coils, including the new one he added just today.
And if it's pvc hot water pipe for his former? Along with any other info needed.
   As the Doc would like to see some replication efforts, instead of just comments without hands on, to back things up.
   I think that the Doc's been reading my post, and finally is showing the possible effects of the stray AC output on his AV plug/led tester, that he is now showing on his last video today. Although he calls it something else.
  So, bottom line is... That there is more to this than meets the eye.
  And, we could use his help, here on this thread, as well.
  So,   Dr. Stiffler,  please sign in and give us a hand.
