THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
WhatIsIt
Chris,
What are you advertising?
Your device or
Your forum AboveUnity.com ?
WhatIsIt
Chris,
Dont forget,
I was the first one welcomed you back,
Then Chet accepted the idea that this time something positive may come from you. He forgot old fights and tried to make all of this works.
He gave his best.
We all supported you!
Then you started to be rude and insult everyone.
I tried to make your device, but I failed.
Can be my mistake and I did not claim it does not work.
You never tried to make further efforts to make small pdf with more detailed instructions which we asked you to do.
You just copy paste same text, together with advertisement of your forum,
over and over, claiming cop >1 (1.9) without any measurements or explanations,
and keep insulting people, but later deleted your insults and posts.
Now we are loonies?
https://overunity.com/15395/partnered-output-coils-free-energy/dlattach/attach/176302/image//
http://www.rexresearch.com/kawai/1kawai.htm
REGAUGING
and Multivalued Magnetic Scalar Potential: Master Overunity Mechanisms
by T.E. Bearden
© 1996Introduction ~
This is a flash release of information on the operational principles of three overunity electromagnetic engines that are in the successful prototype stage or advanced engineering development. My purpose is to provide an explanation of the master overunity mechanisms utilized by these devices, and to alert researchers and experimenters that the mechanisms are well-established in the conventional scientific literature, though still but little known to the majority of electrical engineers.
My series of articles[1] on overunity engines and mechanisms, for The Virtual Times, Internet node www.hsv.com, covers these three engines, the master regauging mechanism, the multivalued potential, and several other overunity mechanisms or proposed mechanisms. The magazine has just released my latest article over the Internet, entitled "The Master Principle of EM Overunity and the Japanese Overunity engines: A New Pearl Harbor?" The article is heavily referenced and gives a thorough explanation of the three overunity devices: (1) Johnson's nonlinear boosting permanent magnet gate, [2 ,3] (2) the Takahashi engine, and (3) the Kawai engine.
All Three Engines Use Regauging of Magnetic Scalar Potential ~
All three devices freely asymmetrically regauge (A-regauge) (recharge or discharge, as required) the magnetic scalar potential energy of the device in a selected A-regauging sector.[4 ,5] Johnson uses a multivalued magnetic scalar potential to accomplish this A-regauging completely by means of a nonlinear permanent magnet rotor and nonlinear permanent magnet stator, without any electrical input. Takahashi and Kawai both use external electrical input to create or alter a magnetic scalar potential in the A-regauging section.
Conservative and Nonconservative Fields and Multivalued Potential (MVP) ~
Normal engine designers work with conservative fields, which require single-valued potentials. (See Figure 1). They consider A-regauging operations, as well as the multivalued potential (MVP), to be nuisances, since A-regauging may immediately involve nonconservative electromagnetic fields (see Figure 2). Most of the favored "engine design" laws and trusted circuit laws "blow up" during A-regauging, whether by electrical injection or the MVP region. So electrical power engineers just design conventional electromagnetic engines to avoid the MVP or eliminate it. On the other hand, if one deliberately evokes and properly uses the free "jump" of stored potential energy that occurs in an MVP-containing sector of an engine, a standard gauge-theoretic analysis will show that one can legitimately have overunity coefficient of performance from that engine. (See Figure 3). I first pointed this out in 1980.[6 ]
                            http://www.rexresearch.com/kawai/figure3.jpg
But : conventional industrial electric motors and generators are not concipated - warranty preserving - to reach possible limits related  given material potential !
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=20020425&CC=US&NR=2002047346A1&KC=A1
[0013] All DC permanent magnet motors run the risk of demagnetization of their permanent magnets if the electromagnetic field of the windings exceed the coercive force of the permanent magnets. To alleviate this problem, a maximum safe operating voltage for any DC permanent magnet motor is specified which under maximum power conditions (i.e., at stall) the resistance of the electromagnet windings will be high enough to prevent a flow of current through the electromagnet sufficient to cause irreversible damage to the permanent magnets. This current is considerably greater than the normal operating current, and for this reason, normal operating conditions for traditional permanent magnet DC electric motors only utilize a fraction of their true power capabilities based on their permanent magnets.
                                  In fact, most of these motors only utilize between 10% and 25% of their true potential.
So new concepts must remark/recognize and accept mass production devices limitations ! Optimizing conventional motors 4-5 times :
        10% x 4x or 5x =   40 to   50 % real efficiency
        25% x 4x or 5x = 100 to 125 % real efficiency
                                                               The Kawai engine C.O.P. without pulse- on/off duty cycle- dc ?
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=kango+iida&IN=&CPC=&IC=&Submit=Search
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19820817&CC=US&NR=4345174A&KC=A
        distance and effect
The operation of the inventive engine 10 will now be described. It is first to be noted that the pull of an electromagnet varies as a function of the area of the holding surface muliplied by the square of the flux density divided by a constant. Also, that the flux density increases as the distance to the holding surface decreases. Hence, changes in the flux density is the greatest contributor to the pulling force of an electromagnet. Experiments conducted by the inventor have shown that an electromagnet powered by two "D" cell batteries can produce a holding force of 500 pounds and that the magnetic attraction force varies with the distance between the surface of the electromagnet and the item to be lifted. It was found, that at a distance of one-eighth of an inch, the force is approximately 7.8 pounds; at a distance of approximately one-twelfth of an inch the force is 31 pounds; at a distance of approximately one/twenty-fourth of an inch the force is 125 pounds; and, as stated, at contact, the force is 500 pounds. Thus, a usable force begins when the distance is one-eighth of an inch and increases rapidly thereafter.
                        the transformer gap,distance :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=21&ND=3&adjacent=true&locale=en_EP&FT=D&date=19990720&CC=US&NR=5926083A&KC=A
Thus, the inventor examined as described below how much the flux of the permanent Magnet 1 contributes to the induction of the third flux 13 in FIG. 2. First, the inventor provided static magnet dynamos of the basic configuration indicated in FIG. 1, one with a permanent magnet 1 and another without a permanent magnet 1. The inventor then compared the power levels needed to induce fluxes of equal flux densities to the second core 3 of each embodiment, that is, the power levels supplied to the magnetized coil 4. As a result, an embodiment with a permanent magnet 1 required only a very low power level to be supplied to the magnetized coil 4. It was observed that the power level required was no more than 1/40 of that of the embodiment without a permanent magnet 1, depending on the test condition.
ramset
Chris quote
Chet, nothing has changed here, only the names! end quote
Chris there is no "here" anymore...it is everywhere..instantly global communications to billions ..who have access..but not the billions more who don't .
every thing has changed in the few months since your new topic started..Fear is not an option ....half measures will not get the job done.
One anomaly... shared.. in one instant [when taught to successful public replication] will bring all we hope for.
The world is being bound into a loop ATM ...we need another loop to keep us free...
None of us are free till everyone of us are free ...like the price of sunshine, air etc etc..seems our destiny _here_ on planet earth 2020....
Just one anomaly taught and shared will do !
Thanks Grandma
AlienGrey
Quote from: ramset on June 30, 2020, 07:59:23 AM
Chris quote
Well why do you ignore THIS little hush hush fact ?
https://www.gaia.com/article/project-serpo-zeta-reticuli-exchange-program?utm_source=google+paid&utm_medium=cpc&utm_term=&utm_campaign=1-USA-DYNAMIC-SEARCH&utm_content=UFOs+&+Aliens&ch=br&gclid=EAIaIQobChMIsfCSrMyp6gIVb4BQBh1uSA6tEAMYASAAEgJBUfD_BwE
So does this make ZPE a reality ?
