THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
WhatIsIt
You can loose your existing members too,
don't forget about that!
WhatIsIT,related #305/306 :
https://patents.google.com/patent/US8847720B2/en
The generator has 10 interlocking inductor and inductee sections. The overall dimension of the nominal generator is approximately H4.5 cm×W4.5 cm×L35 cm, not including the casing=708 cm3 (43 In3), not including the automobile battery or computerized control module.
Inductors
The inductors are in a parallel circuit comprised of 1000 lengths of wire, the ampacity of which is 64-73 amps. Each inductor interlocking section has a common permeable core of laminated sheets.
Inductees
The inductee interlocking sections are in parallel circuit, comprised of 11040 lengths of wire.
Induced Voltage
Vs=Ns/Np (Fp).=11040/1000 (Fp)=11.04 (Fp). At 400 Hz AC inducing current, the induced voltage=4416 volts; at 800 Hz=8832 volts; at 3 KHz=33.12K volts; at 6 KHz=66.24K volts; at 60 KHz=662.4K volts; at 600 KHz=6,624K volts; at 780 KHz=8,611.2K volts.
Induced Current
Is=Np/Ns (Ip)=1000/11040 (55)=4.98 amps (Note: while larger units could have larger cross-sectioned wires, capable of higher ampacity, the amperage in the inductees will always be relatively low, because of the inverse ratio of wires).
Resistance of Circuits (R=I/V)
Inductors=55/240=0.229 ohms; Inductees=4.98/4416 volts at 400 Hz=0.00113 ohns. At higher voltages, resistance is lower. At higher frequencies, circuit resistance increases
Flux(Inductor's Voltage×T[frequency]/N[number of wires in inductor]=V(T/N)
240(400/1000)=96000/1000=96 webers; at 800 Hz=192 webers; at 3 KHz=720 webers; at 6 Khz=1,440 webers; at 60 Khz=14400 webers; at 600 KHz=144,000 webers; at 780 KHz=187,200 webers.
"B" Field=Flux/A
Length of Inductors is 0.35 m, height is 0.08 m, Area=0.35×0.08=0.028=96/0.028=3428.57 webers
"H" Field=I/2Pi(r)r=average distance from inductor to inductee
I=55 amps, r=0.025 m
55/2(3.1416)(0.025)=350 amps/meter
Net Power Output after Feedback of 13.32 Kva
The net output at 400 Hz is 16.871 Kva (22.6 Hp); at 800 Hz, 33.7 Kva (45.2 Hp); at 3 KHz=128 Kva (171.5 Hp); at 6 KHz=256 Kva (343 Hp); at 60 Khz=2.560 Kva; at 600 KHz=25.60 Kva; at 780 KHz=33.254 Kva.
Generator Rating Per Hour and Observations
The cyclic output per second is multiplied by 3600 to indicate the generator's hourly rating. Thus, at 400 Hz=60.7 Kva/h; at 800 Hz=121.4 Kva/h; at 3 KHz=460.8 Kva/h; at 6 KHz=921.6 Kva/h; at 60 KHz=9.26 Mw/h; at 600 KLHz=92.166 Kw/h; at 780 KHz=119.7 Mw/h.
A large home typically requires 15-20 Kva AC; an electric automobile 20-30 Kva DC. A medium-sized heliostat installation may generate 20 Mw; a large one 280 Mw.
Three linked nominal generators operating at a frequency of 780 Mhz (see above) provide more power, with incomparably less investment. The simplest method to increase output of a given generator is to increase the frequency of the inductors current, as shown in the calculations above. Obviously, the output of smaller generators may be combined via a parallel circuit, thus increasing the output of the installation. Full Wave DC is the preferable output for small generators, since the apparatus to which they would supply electricity would generally be small (requiring DC at a low amperage).
Compared :
https://en.wikipedia.org/wiki/Optical_rectenna
f.e.
http://www.novasolix.com/
https://l0dl1j3lc42iebd82042pgl2-wpengine.netdna-ssl.com/wp-content/uploads/sites/2/2018/11/materials.jpg
https://www.tek1up.com/blogs/news/a-90-efficient-solar-panel-is-it-even-possible
https://ieeexplore.ieee.org/document/8605910
Novalsolix uses microscopic antennas to capture the light energy "as very high frequency alternating current and then use a diode to convert the alternating current into usable direct current.
Each carbon nanotube antenna is about one micron (1/1,000,000 th of a meter) long with a diode on one end that operates at frequencies approaching 1 PHz or one quadrillion cycles per second.
To correct: in the article to read :  one micron ( 1/10,000,000 th of a meter )
Compare that to  AM radio, which operates at around one million cycles per second.  AM antennas are about a meter long.
Because NovaSolix collectors place  "roughly one million tiny radio receivers per square inch, they are able to retrieve frequencies "from low infrared through visible light and up into the ultraviolet."
This are 1,55 billions tiny radio receivers per square meter and if with 45% efficiency we get by 1333 W per sqm solar konstant radiation 600 W/sqm electric energy conversion
        = 600 W/ 1,55 billions tiny radio receivers
        3.87096774e-7 Watt per receiver
                                          one quadrillion cycles per second x 1,55 billions cnt x 3600 = 1 hour conversion work per sqm
                                         It is not easy to trap free/unbonded energy in masses and to convert to useable DC or 50/60 Hz AC quantity electricity  !
                                         Both examples need electric energy intermittent storage,for start process or because day/night phase !
                                          "Portable" : Dr, Pavel Imris generator in 1 KW 220 V /50 Hz  range minimum weight (all inclusive) : 15 Kg mass
        shoebox volume
The technology is in existence, entering
https://worldwide.espacenet.com/searchResults?AB=&AP=&CPC=&DB=EPODOC&IC=&IN=&PA=alvin+marks&PD=&PN=&PR=&ST=advanced&Submit=Search&TI=&bcId=1&locale=en_EP&page=1&return=true
and studying the "cited documents" applicants and inventors you will find the "users" and technology first interests ! Universities,Army,NASA,ESA,......
WhatIsIt
Lanca,
I love you because I do not understand you, but will eventually.
If I have FE mobile box, I dont need storage.
Maybe small battery for starting.
Thats the beauty of mobility and unlimited energy.
WhatIsIt
Lanca,
Talking to Mr.Gear I found out that all known principles of FE are already locked up in numerous patents which big companies holds.
So, if we find anything, nobody will be able to cash it in any way.
It will be only for us.
For poor to stand on their feets.
But it will change world and remove energy slavery.
We are all looking down on ground and never look up.
If there are so many resources on Earth, how much of resources are in other parts of our solar system?
Who will have rights to travel there?
And it is not ocean that you can swim accross.
The companies which holds patents and rights on FE device and gravity drive will dominate and regulate that part.
Just like cars, you can make your car, but can not go to highway or road with it because it is not licenced type of wehicles.
And those things are already happening, while we look at ground, unaware.
WhatIsIt
There is no antigravity.
All those small ships operate by creating its own gravity point in centre of vehicle.
Gravity centre is a size of small ball.
Gravity centre affects ship and small area around ship.
If you move gravity centre from centre of ship in any direction, ship will follow.
Crew compartment is always above the centre of ship so gravity for them is always below their feet, and is always down for them.
Because gravity centre is changing position rapidly under feets of crew.
crew can experience desorientation like in free fall from plane with parachute,
if they jump for the first time.
Ships operates in frequency ranges from 1.2 Th above.
Because high frequency it influence all atoms of crew and ship at same time,
so there is no inertia.
Moving gravity centre is made by use of 3 emitters.
Changing power of any of 3 emitters will affect position of gravity centre.
Ship is in shape of saucer so it disipates waves horizontaly,
otherwise ship will start to spin around itself,
if it is sphere shape.
So, you see, it is not even secret anymore, because new era is comming,
and big companies will have rights to it.
Only them.
All is already made for next stage.
