THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
WhatIsIt
And gravity drive exists only because we are surrounded by medium,
aether, space.
Call it what you want.
It is in between particles, atoms, all around us.
Gravity drive uses difference in pressure of medium.
If you create low pressure of medium in centre of your ship,
medium will push matter towards low pressure area.
They know this for a long time.
WhatIsIT,did you read #329 and think ever about this topic disputation theme in the last two weeks !?
https://lockhaven.edu/~dsimanek/museum/themes/simplmach.gif
https://www.researchgate.net/publication/301905364_Experimental_study_of_energy_harvesting_in_UHF_band
        7,7 mW ( to Joule : 0,0077 J/s )
                                    when 1 h this value harvested = 27,72 Joules / 3600 = 0,0077 Wh
https://lockhaven.edu/~dsimanek/museum/themes/whynot.htm
It's irrelevant, but interesting, to consider just how much energy is stored in a small experimenter's magnet. That information isn't easy to find on the web. I was astounded at how small it is, and asked Rick Hoadley to do an independent calculation, which agreed with mine.
Rick considered an Alnico-5 magnet, in the form of a bar magnet is 6" x 1" x ¼" in size, a volume of about 2.5 × 10-5 cubic meters. The energy stored in an Alnico-5 magnet bar of that size is 1.2 Joules. [If you used a stronger magnet, say an NdFeB magnet bar, it would store about 14.7 Joules.]
                           1,2 Joules / 27,72 Joules energy harvester   ;)
                         14,7 Joules / 27,72 Joules energy harvester    ;)
Quoting Rick:
1.2 Watts for 1 second is = 1.2 Joules = 1200 Watts for 1 ms. A typical hair dryer uses 1200 Watts while it is running. If there is an easy way to take the energy out of a permanent magnet with 100% efficiency, it could run the hair dryer for 1 ms. That's all the energy in the magnet, 1.2 Joules.If, however, you had a similarly sized NdFeB magnet, it could run the same hair dryer for almost 13 ms! Wow, one hair might get dry!
Thanks to Rick Hoadley, The Magnet Man, rhoadley@execpc.com for the calculations.So anyone supposing they could "extract" considerable energy from magnets to solve the energy crisis had better rethink the matter.
https://www.coolmagnetman.com/magindex.htm
                                                               About economy and "portability" :  ;)
                       So using the 1200 Watt hair dryer 15 minutes means to use the energy stored  from :
                      15 x 60 x 1000 x  (6" x 1" x ¼" in size) AlNiCo-magnets = 900 000 permanent magnets units
                     https://allmagnetics.com/alnicobars.htm  0,0667 Lbs/inch = 0,4 Lbs per magnet
                     https://www.google.com/search?q=1+lbs+in+kg&rlz=1C1AVFC_enPT797PT797&oq=1+lbs+in+kg&aqs=chrome..69i57.6076j0j7&sourceid=chrome&ie=UTF-8
                     900 000 x 0,4 x 0,453592 Kg = 162 293 Kg magnet material or  162,3 tons  ::)  or "only" 162,3 tons/13 =
                                                             12,5 tons neodym magnets
          for understanding the numbers and calculation : 15 minutes are 900 seconds and 1000 ms are 1 s  and 1000 mW are 1 Watt
                       WhatIsIT,when I want to use an halogen mini baking-owen with 1500 Watt and 1 hour use ?
                      or  compact   https://www.ebay.co.uk/c/26030340399?iid=193545621910
                           ALNICO or neodym magnet compared to the energy harvester the energy storage/conversion !
                                      https://thebulletin.org/2017/05/clean-energy-and-rare-earths-why-not-to-worry/
                                                       compared :
                      https://www.amazon.com/Yinlong-66160H-Battery-Energy-Storage/dp/B07P1MZY5T
                                    https://www.allaboutbatteries.com/battery-energy.html
Joules are units of energy or work
The Joule is the International Standard unit of energy defined as one watt-second. One watt-second of mechanical work is the work done by a force of one Newton (or 0.2247 pounds) pushing through a one-meter distance. 3600 Joules are contained in one watt-hour since an hour contains 3600 seconds. Batteries are often rated in milliampere-hours instead of watt-hours. This battery rating can be converted to energy if the average voltage of the battery during discharge is known. For instance, a 3.6-volt Lithium-ion battery rated at 850 mAh will maintain a voltage of 3.6 volts with little variation during discharge. Multiply the voltage of 3.6 volts times 850 mAh to yield 3060 mA-volt-hours or 3060 milliwatt-hours. 3.06 watt-hours equal 11016 watt-seconds or Joules.
        E=hf
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19910523&CC=DE&NR=3938577A1&KC=A
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3938577&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
The energy balance of the converter is as follows: Input: electrical energy Output: + permanent magnet energy Power balance:
                                             The power is frequency-dependent:
        L = (WE + WM) x Hz
        and frequency are cycles or RPM
#336 :   one quadrillion cycles per second x 1,55 billions cnt x 3600 = 1 hour conversion work per sqm
What in future will become possible,by good cooling ( converter material melting point !) :
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=5356484A&KC=A&FT=D&ND=3&date=19941018&DB=EPODOC&locale=en_EP
The above test used diodes with active diode areas of 10@-4 cm@2 as convenient to the fabrication and the tests. In the theory of the quantum reversible process, the output voltage is not dependent on the area of the diode electrodes. The test results do not support the existence of any electron thermalization process in which any significant fraction of the hot electrons is first thermalized to an equilibrium temperature for electrons. This thermalization process is not compatible with the experimental results, since approximately 10@13 watts per square meter of input power is needed to heat the thermalized electrons to the electron temperature of 6000 DEG K. for an electron photon thermalization time of 10@-12 seconds. This electron thermalization process is also not a physically realizable process for this input power, since the material of the diode is destroyed in less than 10@-12 seconds by this intensity of incoming photons.
This power is 6 orders of magnitude larger than the test power for the conversion process of 10@7 watts per square meter that was used in the experiment. These results support the conclusion that the thermal energy of the hot electron is directly converted into electromagnetic energy before any electron thermalization occurs.
Diods and "relaxation time" : https://www.toppr.com/ask/question/define-relaxation-time-of-the-free-electrons-drifting-in-a/
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=12&ND=3&adjacent=true&locale=en_EP&FT=D&date=19880119&CC=US&NR=4720642A&KC=A
DEFINITIONS
Macro Regime: The regime for large-scale devices having a dimension L>0.5 .mu.m, in which conventional electrical laws apply.
Quantum Regime: The regime for submicron devices having a dimension L<0.5 .mu.m, in which the laws of quantum electrodynamics apply.
Femto Sec.: 10@-15 sec (Femto means fifteen) The light period (time per cycle) for blue and red light respectively varies from 1.3 to 2.3.times.10@-15 sec or 1.3 to 2.3 Femto sec.
Femto Diode: A diode of this invention operating in the quantum regime which is reponsive to visible light frequencies.
"Energetic" Electron: An electron which has absorbed a quantum of light energy (1.8 to 3.1 eV) and which is traveling in the metal cylinder in its own conduction band at a corresponding large velocity and distance almost without collision; and which exhibits quantum regime properties.
"Thermal" Electron: An electron which travels at a small velocity due to its thermal energy of about 0.025 eV; which makes frequent collisions; and which exhibits macroregime properties.
                                                         TIME PER CYCLE      E=tc² Nikola Tesla energy formula
        or
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=12&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931012&CC=US&NR=5252176A&KC=A
A good question of this system is how a particle such as a photon traveling at the speed of light could be further accelerated as it passed through this crystal. The answer to that question could be that the crystal accelerator provides an energy gain from its strong nuclear forces to the particles which shows up as an increase of their effective mass. Another answer is that the energy law E=Mc@2 is changed when radiant energy units are subjected to certain forces such as the nuclear forces in the crystal. The speed of light is no longer limited and it conforms to the new equation E=McX. The value of X in the crystal approaches 3.times.10@20 meters per second.
WhatIsIt
Thank you Lanca,
This is much better, you actually explained with your words what are you quoting,
so now I can follow what you trying to say.
It was very hard to follow just links and imagine what you try to show.
OK.
seychelles
SO LANCA HOW MUCH ENERGY IS STORED IN A MAGNIFYING GLASS. AND YET IT FOCUS THE SUN
LIGHT TO A POINT AND BURN WHATEVER IS THERE. SO IS A MAGNET, IT IS A MAGNIFYING GLASS
OF ETHER IT FOCUS AND COMPRESS ETHER. ALL ENERGY IS DERIVED FROM ETHER. THAT IS MY
THEORY.
ramset
Lanca
Your lockhaven link won't open on my computer
But ok on phone
I have not read all however this part (looping COP 1.1 to runaway)
I found encouraging and hoping many such devices will
Be shared!
By members of Elite aboveunity forum !
So here we can open source for those less fortunate [who don't have the required money or equipment ]?!
Thanks Grandma
