THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
Hello seychelles ( and Komoren,Andamannen,....... ::) )
your comparison is -from my standpoint- not certain :
your magnifying glas/lense,spectrum,focus does not intensify absolut the radiation energy content but concentrates it to a focus area/point !
When you study " concentrated photo-voltaic" concepts : 1 sun concentrated as "20/200/2000 suns"-factor
Factor 1000 example http://media.treehugger.com/assets/images/2012/09/solenspheredesign.jpg.492x0_q85_crop-smart.jpg
                               https://www.pres.org.pk/2012/new-concentrator-technology-reduces-pv-surface-area-by-factor-of-1000/
When you think it is certain why reach Owen Barker by his panels/magnets device a double output voltage ?
https://overunity.com/16681/24365-solar-cell-output-theory-and-experiments/   Reply #6
The highly conductive magnets such as the aforementioned wrapped magnets may actually be performing four different functions:
(1) the movement of photons towards a given solar cell surface;
(2) the bending of electrons which might otherwise miss a solar cell surface towards the actual solar cell itself;
(3) the movement of unabsorbed photons passing through a given solar cell towards the surface of the next adjacent solar cell;
(4) the conduction of current down the stack of solar cells so as to increase electrical output in series.
We do not anymore talk about Magnesia/-it-magnetism,in AlNiCo and Samarium and Neodymium we use radioactive decay forces,Betavoltaic battery type !
What we can accept that this magnet energy is given by a small magnet active surface area
#344 : Hello Chet ,
the in the  https://lockhaven.edu/~dsimanek/museum/themes/whynot.htm article 110% efficiency engine is to understand as "hypothesis",not as existent scheme device !
You asked some posts before about anomaly :  https://phys.org/news/2012-03-efficiency.html
In their experiments, the researchers reduced the LED's input power to just 30 picowatts and measured an output of 69 picowatts of light - an efficiency of 230%. The physical mechanisms worked the same as with any LED: when excited by the applied voltage, electrons and holes have a certain probability of generating photons.
but by given quantum energy efficiencies up to average 200%
https://books.google.pt/books?id=0H4bWIpaXb0C&pg=PA348&lpg=PA348&dq=m.i.t.+200%25+conversion+efficiency&source=bl&ots=yLNW6ymeT4&sig=ACfU3U1rPbtNkJ4TaYvRP1oh4uBo1a5Qvw&hl=de&sa=X&ved=2ahUKEwjJxdyUsrvqAhUGJhoKHV7_CioQ6AEwDHoECAwQAQ#v=onepage&q=m.i.t.%20200%25%20conversion%20efficiency&f=false
https://e-catworld.com/2020/06/30/surprisingly-strong-light-and-heat-from-nanogaps-between-plasmodic-electrodes-rice-university-study/
https://pubs.acs.org/doi/10.1021/acs.nanolett.0c02121
Our measurements over a large ensemble of devices demonstrate a giant (∼104) material-dependent photon yield (emitted photons per incident electrons). This dramatic effect cannot be explained only by the radiative field enhancement due to localized plasmons in the tunneling gap.
"partnered output coils"(effect)-devices
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=30&ND=3&adjacent=true&locale=en_EP&FT=D&date=19940519&CC=DE&NR=4238587A1&KC=A1
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=27&ND=3&adjacent=true&locale=en_EP&FT=D&date=19960215&CC=DE&NR=4428026A1&KC=A1
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=4428026&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
Fig. 1 shows the basic circuit diagram of a DC / AC converter. The capacitor 11 charges via the changeover switch 12 and the primary winding A of the transformer 13. The self-induction generated in winding A is stored in winding A via diode 14. When the changeover switch 12 is switched over, the capacitor 11 discharges via the winding B of the transformer 13. The self-induction generated in winding B is stored in winding B via diode 15, etc. Since the windings A and B of the transformer 13 are connected in push-pull, an alternating magnetic field is generated in the transformer core, which generates a corresponding electrical power in the winding C of the transformer 13.
bistander
Quote from: lancaIV on July 07, 2020, 10:59:18 AM
#344 : Hello Chet ,
the in the article given 110% efficiency engine is to understand as "hypothesis",not as existent scheme device !
Hi guys,
I've seen this before. You can read in the provided link:
" took advantage of small amounts of excess heat to emit more power than consumed"
So it is not proof of OU.
Regards,
bi
Quote from: bistander on July 07, 2020, 11:44:22 AM
Hi guys,
Regards,
bi
bistander,
from the contexte
" The researchers didn't try to increase this probability, as some previous research has focused on, but instead took advantage of small amounts of excess heat to emit more power than consumed. This heat arises from vibrations in the device's atomic lattice, which occur due to entropy. "
you not include that " This heat arises from vibrations in the device's atomic lattice, which occur due to entropy. "
so the total output related total input release " over unity effectivity" !
It is internal heat generation,not from the ambient/outer environment !
