THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
ramset
Johan
here the vid again https://www.youtube.com/watch?v=c3I2zeoUbzg
IMO this must be a repost of original builders work from another location.since you tube channel you shared uploaded it .
Magluvin is not "mine" he is a hens tooth...one of the rarest species on the planet ...an open source researcher who shares his work [schematics spoonfeed etc etc]....an open source builder extraordinaire .
I have asked others and now will ask a few more...
IMO the biggest problem for this one ...the technology to build what we see in the vid has been around since ...?..?...Just after the first guy with a wheel met the second guy melting ore...Did we have soo many ""stupid people""[not my words] ? or do we have tricksters...or should we be cautious first ?
I will look again for topic here where this was discussed .
Chet K
Thanks Grandma
Magluvin
Quote from: Johan_1955 on July 13, 2020, 08:32:15 AM
Yep, good analitics?, Clear to see the Sparks and the Black Carbon-Tracks from the Sparks on the Flat-Spring!
You could work at the WHO! Chep, is this your Best-Elite-Member?
Regards, Johan
Through all my pulse motor experience, Ive seen low voltage input to do very little if any contact issues and sparking can be minimal to nada by eye. Can add a diode or a small cap to kill spark if any.  Not a very good reason to believe there is not a battery driving the flywheel.  Also it seems the flywheel may not be as heavy as it appears, if it works like the vid implies it does. The acceleration on a slow rotation when the pin contacts the spring seems like a lot considering the appearance of the spring and weight.
Unless you can say you built it and got it working as implied, and then 'show' without a doubt that it works, I call fake. ;)   Its been years since I have seen the vid. Once looking it over a few times, I definitely will not be replicating, and my reasons are based on the evidence I have provided.
Mags
Floor
Quote from: ramset on July 13, 2020, 09:15:30 AM
Johan
Chet K
One does not need a motor in order for a well balanced flywheel to spin for
as long as this one does in the first run in the video.
Without the spring, a very low friction flywheel would continue to rotate for
an even longer time period, than is demonstrated in the video.
The force to bend the spring is 100% returned with the un- springing (its balanced).
No net loss but no net gain either.
The losses are
The spring mechanism causes increased friction.
Against the fly wheel
Within the bending section of the spring
Against the bearings of the fly wheel upon the shaft.
The wheel's turning speed imperceptibly speeds up and then slows down.
This depends upon whether the wheel is loading the spring or the spring is being
unloaded into the fly wheel.
This is why The device would spin even longer without the spring.
A magnet arrangement could replace the spring setup with the
same non O.U. results.
In the second run, in the video, I conclude that there is no reason why the
wheel should continue to run.  None at all.
  I have to cry "fake" on this one.
       floor
WhatIsIt
Any flywheel which has metal shaft is electric motor.
Something observed long time ago.
Just run current through shaft and it will start to spin.
Demo can be seen in those videos. Ball bearing motor.
https://www.youtube.com/watch?v=i7LOF1GZpdo
https://www.youtube.com/watch?v=JhKcaWpodyI
Basically, it is short circuit, zero resistance.
If you drive it with LC resonant circuit, you wont spend much (zero resistance),
possibly parallel for more current. It is current hungry electrical motor.
It is Kapanadze electro mechanical representation of his solid state.
If you watched Kapanadze motor video https://www.youtube.com/watch?v=qVUN3GsekKQ ,
you saw that is slowly gaining speed,
just as motor in video https://www.youtube.com/watch?v=i7LOF1GZpdo
His coil on the shaft has numerous turns, and shaft is secondary one turn, it is transformer.
Kapanadze used this principle to amaze crowd. (picture from his movie).
WhatIsIt
Now,
if you know how electro mechanical system works?
Can you make solid state?
There must be secret how to tap into LC resonant without disturbing LC resonant,
First, it must be zero resistance,
but, what else?
