Split Flux Transformer
Started by SkyWatcher123, May 11, 2017, 01:28:03 PM
Magluvin
This was from the pdf of what I had done but with 5 cores instead of 3. Basically it is a culmination of the other ideas in the pdf as a final design.
Mags
F6FLT
All the coils are coupled, they all influence each other. The power supplied to one or more will be distributed to the others. A resonance will not change anything except the distribution of the coupling which will no longer necessarily share the power equally between each coil. But in any case the sum of the captured energies cannot be greater than the one provided, there is nothing new here that could produce something unexpected.
Big process,  small process, nano process and converting device :
https://en.m.wikipedia.org/wiki/Optical_rectenna
https://en.m.wikipedia.org/wiki/Infrared_spectroscopy
                           Infrared or vibrational( temperature ?) : near-/ mid-/ far IR
If something is too big : divide et impera it!
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=Concentrator+solar&PN=&AP=&PR=&PD=&PA=Winston&IN=&CPC=&IC=
Fraktionieren,  making transform-/useable
https://patents.google.com/patent/US6910332
https://peswiki.com/directory:fellows-thermoacoustic-cycle-tac-generator
Art/-En & Weise/-n :  Kind/Kinds& Modus/Modi
This here,  Magluvins prototype, is an opto-electric or acousto-electric device
https://wikivisually.com/wiki/Rebecca/Eureka_transponding_radar
       near/ mid/ far field detector/ transceiver  ( and responder, by all own responsibility)
          Spieglein,Spieglein,an der Wand ,.......
         Was wohl die Wand antwortet: Mene-left Mene-right , o vale me deus !
         Oder : Hier spricht der automatische Spieglein-Recorder : bin gerade nicht anwesend!
                     "DU" kannst MIR aber jederzeit... ..... :P ??? ::) ;)
seaad
I have made some quick tests according to (Magluvin Reply #65 above)  with the "main principle" multi core transformer.
I did the tests with my Fluke multimeter and with my Oscilloscope for the phases.
Tests are at 10 kHz.  And the load resistos are chosen so they reduces the free "swinging" output voltage to about halv  that voltage,  in all tests. All coils 100 turns.
A   Open cores       FLUKE      IN:  1,89 V  6 mA          82,6 degrees        OUT:  0.24 V    65 %       10KHz      Load 59 Ohm
B   Closed core      FLUKE      IN:  1,85 V  4.15  mA     60,3 degrees        OUT:  0,86 V    88,7%     10 kHz     Load 217 Ohm
No extra here.
Regards Arne
seaad
The resulting effect comes when I'm using one  plus two pairs of my HV TV cores. KÖNIG ELECTRONIC FAT100  A single loop and a double core loop.
Pic @ 10 kHz
Regards Arne
