A3C & X-MAGNETS AND PMF.
Started by ageofmagnetizm, May 19, 2017, 08:07:51 PM
ageofmagnetizm
Many similar tests with various loads has produced the same result and on following picture generator is testing with certifyed 100 ohms / 500 watts immersion water heater where AC current causes increase of temperature of thermoelectric resistor where rising temperature causes increase of resistance of electric circuit.[/size]
[/size]
https://youtu.be/CeVwXykgaLI
above is link to short video where AF PMG-MMEIR 4E8M is being tested with no load connectet to circuit, and then video is paused and continue with testing of generator connected with 5 ohms electrical inductor, and paused and continue with testing of generator with cold thermoelectric resistor with measured 77 ohms. During three tests multimeter display same approximately 260 AC voltage what is obvious manifestation of expected Zero Magnetomotive Feedback and unexpectually discovered Hyperefficiency where output electric power is many time greater than mechanical input power of drive motor.
Shall continue...
Updated 10 may of 2018 by Taras Leskiv
sparkmen
hi ageofmagn,
either intentionally or not, your measurment is not the proper one,
good job anyway
rgds
ageofmagnetizm
Sparkmen,
thanks for such brief and elogant expression of your mind,
now I know your attitude and have to guess what you actully mean.
Just read all previous discussions of measurements which went to be fullish and
do not repeat same suggestions for the second time.
sparkmen
ageofmagnetizm,
not meant to offend, even if you connect 10kw load and measure voltage in series, you'll still have 260v...
will be nice to see what voltage come across any load, will give more info
rgds
citfta
A wise man listens to good advice.  A foolish man ignores it.
