A3C & X-MAGNETS AND PMF.
Started by ageofmagnetizm, May 19, 2017, 08:07:51 PM
ageofmagnetizm
Gyulasun,
Your MEGAOHMHYPOTESIS has been easyly shattered by connection
of one 10 watt LED directly to generator, which normal light proves that
your megaohm calculations are 3.5 digits wrong.
Now, please take vacation from posting here untill next information will
be released, instead find place where your analitical talents are demanded.
Hello ageofmagnetizm (Taras),
you are in the "patent application"-stage,
later for introducing the generator as industrial product you must your decice get technically tested to get the technical approval ,in Europe this are the professional institutions and certificating entities like TUEV and DEKRA !
The patent office approval to become your claims granted means to get commercial rights,
without technical certification these granted rights are worthless !
You think,by the used measure method and the tested and repeated results,to have a super-efficient electricity generating device :
                                                              " BRAVO ! "
                and super world-wide generator sellings are wished to you and all of us
  We are not in hurry and can still wait for the next stages of progress,hopefully positive !
Sincerely
             OCWL
gyulasun
ageofmagnetizm:
My "MegaOhm" calculations are not shattered because you used your DMM in series connection with a load,
you KNOW this! Your generator output remained unloaded in your video demonstrations, you KNOW this.
Now you try to offset this by a 10W LED you connect directly to the generator output: Nobody stated that
your generator is unable to drive a 10W load  directly  when the generator is driven
by a 16-17W motor as the prime mover.  HOW can you compare the two different cases: series and parallel??
Your videos so far showed your DMM (set in AC volt range) was hooked up in series with any load you used.
Of course you need to show correct input power measurements to your prime mover motor (input DC current and
voltage your DMMs are able to measure
),  to make sure the connection of the 10W LED to the generator output
would not increase the basic 16-17W input power of the drill motor.
If input power increases when you hook up the 10W LED (or say a 40W or 60W incandescent light bulb)
to the generator output, then efficiency should be considered with the measured input power, of course.
I understand you do not like my posts here.  A coin has two sides: I do not like being looked to be a fool
when you try to imply in your videos, blogs and posts you have 1000% 'hyper'efficient setup and you try to
"prove" it by incorrect measurements.
Looking forward to your further activity.
Gyula
Quote from: ageofmagnetizm on May 16, 2018, 03:02:41 AM
Gyulasun,
ageofmagnetizm
Gyulasun,
You only have to look somewereelse to post,
Otherwise I'll be forced to report your doings as malisious nonsens.
Whish you newer post here again, chao.
gyulasun
Hi ageofmagnetizm,
Gyula
