Thanks to ALL for your help!!
use 1 large drive pulley + many small output pulleys to multiply AC electricity
Started by that_prophet, June 18, 2017, 11:10:24 PM
that_prophet
.       This is so dirt simple that you will kick yourself, after you discover just how super simple this technology truly is. How is AC electricity made, by using rotations of a coil through a magnetic field, and we can use a set of varying sized pulleys to multiply your total # of rotations. So, we can effectively multiply our amount of AC electricity by using simple pulley mechanics.
.      This GEM = (Geometrical Electricity Multiplication) technology is super simple, http://free-energy.yolasite.com/ and is based on basic pulley mechanics. In it, you pay a small amount of DC electricity to rotate a large 100 cm circumference pulley one single time, (one mere spark). Then you run the 100 cm of moving belt, (off the 100 cm of circumference) past a mini-pulley of only one centimeter circumference, giving you 100 rotations, which you covert into 100 cycles of AC electricity, by simply adding an AC generator to it. You are merely using the 100 cm of belt that you get off the single rotation of a 100 cm circumference + by running this length of belt by a 1 cm circumference pulley, with an AC generator attached.
.     Now, you have just multiplied your single burst of DC current into 100 cycles of AC electricity. Please don't listen to the mythical torque problem, because there is no torque problem. This AC generator is running practically torque free, because all that it has to generate is the single burst of DC current that your DC drive motor takes to make one rotation. And please remember, that you get 100 cycles of AC electricity to generate this single "spark" of DC current to power your drive motor, so this is generating practically zero current, divided by 100.
.     If you run wires from your AC generator output, + put them into the input of a full wave bridge rectifier,(4 diodes) + then run wires from the DC output of your full wave bridge rectifier, into the input of your DC drive motor, you should have a working mechanism. This perpetual free energy generator mechanism is complete, + you should be able to start it running by merely rotating the large pulley by hand, a quarter turn.
.     Please don't listen to the torque problem, as it is non-existent. This AC generator is pretty much free floating, as for all of its 100 rotations, it only has to generate one small spark of DC current. That is one small spark of current, that is divided by 100, so you only have to generate 1/100th of a spark of current per rotation, or 1/100th of practically nothing.
.     You must have your AC generator + your DC drive motor of the same voltage.
.     This is so simple + cheap to build guys + gals, please build one to prove it works,,,
I live in a nursing home, so I cannot even have the simple tools to build this with. This is so dirt simple + easy to build, that satan is laughing his as? Off, at how gullible we simple humans are. But he will get his just deserts, when Jesus returns in His Glory, before the second door close on 2025.94 = 2019.04(door for rapture) + 6.9(7 Hebrew years = 2520 days) http://doorschristmustpassthrough.yolasite.com/
.     So we have less than 19 months to live, before all born again followers of Christ, only those who are looking for His Return, will vanish off this earth in the Rapture = "blessed hope" http://my2020vision.yolasite.com/ http://beliefstoliveby.yolasite.com/
that_prophet
that_prophet
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this 1ST DOOR closes on 2019.04 = Jan 14th http://my2020vision.yolasite.com/ - "know that it is near, even at the doors",(Mat 24:33) http://doorschristmustpassthrough.yolasite.com/.
Free Energy + perpetual motion can be easily produced using pulleys, costing only the minuscule bit of power that it takes to rotate a DC motor with a large 100 cm circumference pulley one single time. You can gain or multiply massive amounts of AC electricity using mini-pulleys with AC generators. You are capable of doing this by running this long length of belt, (off the circumference of large pulley) past a few 1 cm circumference mini-pulleys, with AC generators attached. This GEM-(Geometrical Electricity Multiplier) device is gaining you 100 cycles of AC electricity, for every mini-pulley that you choose to attach to this sane belt. So, if you added 10 mini-pulleys, you could get a return of 1000=10X100 cycles of AC electricity, and all costing you only one mere spark of DC current. How could you not be multiplying AC electricity, when you are using simple pulley mechanics to trade one spark of DC current, for 100-1000 cycles of AC electricity-(duel sparks).
This super simple free energy technology: http://free-energy.yolasite.com/ works on the ability of combinations of pulleys being able to easily + freely multiply your total # of rotations. You can do this because of the fact that you don't have to expend 100 times more electricity to rotate a large 100 cm circumference pulley, than it takes to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of moving belt, that comes off the one rotation of a large 100 cm pulley, past any # of mini-pulleys of 1 cm, then you could gain a return of 100 rotations for every mini-pulley that you choose to attach to the same belt. (As for torque, it only comes from generating power, and power is voltage multiplied by current) + We only need to produce one single spark of DC current to make this a self-powering mechanism. So one spark of DC current, (which is practically nothing) multiplied by even massive voltage, would still equal practically zero power, which takes practically zero torque to rotate.
This multiplication of rotations could be extremely helpful, if you only added AC generators to these mini-pulleys, you could be multiplying the total cycles of AC electricity. This AC generator takes no torque to rotate, because although it would be winding up massive voltage, it does not need to be winding up practically any current-(1 mere spark) which is practically zero. Torque is only caused when you are generating power, and you are generating practically zero power, as power is equal to voltage times current. So, no matter how massive of voltage you are generating, it is multiplied by practically zero current, as we only need one spark of current, or practically zero. This works because zero times anything is still equal to zero, and practically zero works the same way.
What is AC electricity, + how is it made = it is made out of the easy rotations of coils of wire through a magnetic field of two oppositely positioned magnets right. Using pulley technology, we can easily + freely convert one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference mini-pulleys that we choose to attach to the same belt that comes off of your large pulley. So, if you added 10 mini-pulleys to this same belt, and added AC generators to each mini-pulley, you could gain you 1000 = 100X10 cycles of AC electricity.
All these cycles of AC electricity are from the single burst of DC electricity, which is the small amount of current that a DC motor takes to rotate one single time =(one mere spark). These cycles of AC electricity would cost practically zero torque to rotate, as torque is only caused when you are generating power, and you are not generating practically any power in this system. This is because although you may be winding up massive voltage,(electrical pressure) to keep this GEM mechanism running, you only need to generate one single spark of DC current, and P=IV, or power equals current multiplied by voltage.
So your total power output would be practically zero current multiplied by any amount of voltage, which would still be equal to practically zero power, taking practically zero torque. So, you could be easily + freely generating massive amounts of rotations of these mini-pulleys, which are generating you massive voltage, or the ability/potential to gain plenty of current, which will allow you to produce plenty of power. This is because the greater the voltage/pressure, the greater the ease that there is to generate more current. PLEASE,,, let me show you how ridiculous this mythical torque problem really is. Do you think that the 100 cycles of AC electricity would have a hard time producing the single spark of DC current, which is all that you need to crank over your DC motor once, with your 100 cm circumference pulley attached?
Mankind was given the best Gift from God, (other than Jesus) http://free-energy.yolasite.com/ right here in Atlantic Canada + just before the infamous 7 years Peace Treaty. This seven years of time, which the 2nd half of is the Great Tribulation, is when this GEM tech will be needed most. This will be the worst time for earth, where not only is there constant war, but most all of the evil fallen angels, and the Nephilum , will be sent to the earth. Nephilum are the offspring of fallen angels + human women, as angels are all male, because God only wanted there to be a set # of angels. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood. (How can we be billions of years old, when the moon will leave orbit within 10,000 years) + all orbiting bodies will have messed up orbits, because of this yearly amount of space debris adding mass.
This is free energy technology, which we all will need and love, as it has practically no cost to run, and there is no need for any fuel to be purchased. Nor would there be any exhaust to cause environmental or noise pollution. So,,, why haven't we figured this simple little bit of technology out long ago? Evil spirits are, and have been hiding this simple technology from mankind. These AC generators are extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant in the bearings) would come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here.
I confirmed that this free energy technology, discovered in the early 2000's, was from God + not from evil forces, by finding it in a UFO motor description in Ezekiel 1:16. Thankfully, there are many ways that we can freely multiply the total # of rotations, like a set of varied sized pulleys, can be easily used to multiply the total # of rotations. Then, by simply adding an AC generator to your mini-pulley, you can convert your rotations into cycles of AC electricity.
This is one super simple GEM of an idea, and it is made from pre-school technology, so why was this not out long ago. Can you believe the power that evil spirits have, to be able to dumb down a whole population of humans + for so long. I still have problems getting people to believe that there is no torque problem. Think that this may actually be a good enough reason for you to find out if GOD IS REAL = http://beliefstoliveby.yolasite.com/ + if HE IS RETURNING SOON = http://my2020vision.yolasite.com/
Do you want to hear how truly super simple this technology is, Where you only pay to crank over the DC motor one time, with a 100 cm circumference pulley, Then you use the 100 cm of moving belt off this large pulley circumference, + run it past one or more mini-pulleys of only one centimeter circumferences, All that you have to do is add an AC generator to these mini-pulleys, giving you a free return of 100's of cycles of AC electricity. That's one small pulse of DC current as an input, returning you 100 cycles of AC electricity output, How can you not multiply your AC electricity, with this rotation multiplication technology
IT IS TRULLY THAT SIMPLE
Come on Canadians,,,
Come on Nova Scotia,,,
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started, (early 2000's when He first shared this with me). Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
that_prophet
PROOF OF CREATION + A YOUNG EARTH = (space dust) has mass + billions of years of dust would add up eventually + mess up the orbits of all planets + moons. We could measure the amount of dust on the moon, and divide the total by the amount of dust that is deposited every year, coming up with an age for the moon, and thereby finding out the age of our earth. Most of us have seen pictures of the moon landing, and realize that there is only a few centimeters, meaning that by the deposit of space dust, the moon has only been orbiting us for a few thousand years. Less than 10,000 year
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,, Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6, 9 + 12 volt batteries, but household 120 volt, + 12 volt, to powering these new electric cars. Let's throw the oil companies out of work, producing toxic smoke + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that either fund terrorist, or which are unknowingly funding them. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, which would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16. http://aliensandghosts.yolasite.com/
Most people have heard that the "day + hour knoweth no man"-(Mat 24:36), but why does nobody mention the soon arriving doors that we are not only allowed to know, but in the original Greek, it is worded like a command = "know that it is near, even at the doors",,, + that 1st Door will close on 2019.04 + the last Door will close on 2025.94. So we are guaranteed that Jesus will set His foot on the Mount of Olives before the year 2026.
Did you ever wonder how you could know that it's near, if we can't know the day. Near to what then, maybe it's near to the door/deadline = "know that it is near, even at the doors" Mat 24:33. Doors are plural, because of the two appearances of Jesus, the first is in the clouds,(Rapture) http://rapturequestion.yolasite.com/ before the 7 year peace treaty is signed + then His second arrival is as His Foot touches earth, on the Mount of Olives. DOOR = (this is not the date of His Arrival, which we are warned that nobody can know, but this is the date that Christ must return before) A day that the Tribulation Saints will not only know, but they will probably being counting down the days until. = (He Returns when the 7 year peace treaty ends)
EVil-sOLUTION = isn't it amazing what Truth can be revealed, when the "il-s" of life are included. http://decimationofthisevolutionfairytale.yolasite.com/
I can give you a free to run, perpetual power supply = http://free-energy.yolasite.com/ This GEM mechanism can do this because of how AC electricity is created by rotations. as in the more rotations the greater amount of AC electricity, and pulleys can be used to multiply rotations. So, you are using pulley mechanics to multiply your total amount of AC electricity, by trading one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference pulleys as you choose to add to the same belt. If you add AC generators to these mini-pulleys then you could be multiplying AC electricity. If you added 4 of these mini-pulleys with AC generators attached, you would gain 400 cycles of AC electricity, and all for the single burst of DC current, the minute amount of current that a DC motor takes to rotate one single time.
These mini-pulleys would be easy to rotate, as the only resistance that they would generate, would be caused by any power that they were generating. These mini-pulleys would only be winding up massive voltages, because the only current needed to rotate your large 100 cm pulley on a DC motor, is one simple spark, or short burst, the amount to rotate your large pulley only one single time. Torque is only caused when you are generating power, and power is generated by current multiplied by voltage. Since we only need one single spark of current, (practically zero) the total amount of power being generated would still be practically zero, costing practically zero torque.
This was given to mankind before the first door closes = http://my2020vision.yolasite.com/
Especially for the soon coming Tribulation Saints http://doorschristmustpassthrough.yolasite.com/
Sorry if it offends you, that I add a little bit of Biblical stuff in my explanations, but when I came up with this super simple idea, it was just after asking God for a way to help the Tribulation Saints. Just think about how super simple this AC electricity multiplier truly is, and how the voices in your head tell you that it cannot work. When how much more simple can it be, then to only pay for the one rotation of a large 100 cm pulley, when you can get a return of 100 cycle of AC electricity, for every 1 cm mini-pulley that you attach to the same belt, (with AC generators attached). Yes that's an input of one single spark of DC current, returning you 100 cycles of AC electricity for every mini-pulley that you attach to the same belt. If you only added 4 mini-pulleys, you would get a return of 40 cycles of AC electricity. Please remember, that there is a most powerful spiritual warfare going on over this GEM technology.
There is a most powerful spiritual warfare going on over this GEM technology. Can you believe the problems that I have had, getting this super simple way of using pulleys to multiply the total amount of AC cycles of electricity? I think that it's totally ridiculous, when you truly take a close look at it. Pulleys can be used to multiply the # of rotations, and AC electricity is made of rotations of a coil through a magnetic field. It should be dirt simple, as you are using pulleys to multiply your total # of rotations, and AC electricity is made of rotations, so you are effectively multiplying AC electricity. .
that_prophet
