EXPLAIN this: 100% proof of OVERUNITY found in GAS TUBE SIGN Power Supply!
Started by pfrattali, June 23, 2017, 02:14:56 PM
Quote from: pfrattali on June 23, 2017, 02:14:56 PM
5X  overunity:
6 Watts input - 30 Watts output - DO THE MATH
http://www.imagesco.com/science/high-voltage/gas-tube-sign-power-supply.html
DO THE RIGHT MATH.
You should be able to run 4 identical units from the output of the first unit, with enough power left over to run a load. Right? And then from each of those four identical units you should be able to run another 4 identical units, each with power left over to run a load. Then you should be able to run sixteen more units from the outputs of the four. With power left over from each one to run loads. Then you should be able to run 64 identical units off the outputs of the sixteen.... and so on.
DO THE EXPERIMENT.  We will all be waiting to see your results.
(Hints: Peak power is not average power, and nameplate rating numbers are not measurements.)
pfrattali
Quote from: TinselKoala on June 23, 2017, 04:20:38 PM
DO THE RIGHT MATH.
Watch this Don Smith video, especially around 23:20.
https://www.youtube.com/watch?v=Mnoy2D4wuf8&t=878s
Acca
 Here is help to you in understanding the plasma method link below... It's is  real and it works ..read this link as it will get you started ...
Acca..
p.s..You may become shark bait being here..
It may in fact be another manifestation of the 'vacuum spin' phenomenon, by creating in an aqueous electrolyte, or even in the cathode itself, conditions somewhat analogous to those prevailing in the Correa apparatus. Indeed, there seems to be no doubt that the Correa technology itself bridges two of the above 'excess energy' categories, electrodynamics and vacuum spin. The Correa method is probably the most advanced of these emerging new energy technologies, being fully reproducible, well researched with its test findings well documented in and protected by granted U.S. patents. It already allows us to tap energy from space itself, or rather the vacuum field activity that fills space, and in contrast with the alternative methods it offers what may prove to be a mobile light-weight power source compared with the heavy apparatus needed where magnets and rotating machinery are involved. Unlike 'cold fusion' which generates low grade heat output, the Correa technology generates electricity at power voltage levels.
Harold Aspden 1996
https://www.haroldaspden.com/reports/08.htm[/font]
