Overunity Device by Tanju Argun (Moderated)
Started by gotoluc, June 23, 2017, 06:28:51 PM
Quote from: Tanju on June 26, 2017, 11:24:39 AM
Dear Luc;
You invited me and therefore I am asking your permission to retire fom this forum.
Maybe I am not fit for this forum.
I do not have to be together with people asking questions like What is cold elecctricity? What is Radiant Energy?
These questions do not fit with the title of this forum.
These people know nothing about Nikola Tesla.
So please let me go back to my silent corner and try to continue with my works.
Thanks and regards
Tanju
P.S. I will not forget mind the sharks! But again my meat is old for those sharks.
You are wrong that "these people know nothing about Nikola Tesla".  If you have confidence in your results you should not shy away from people questioning you and asking you for solid evidence for your claims. Perhaps instead of feeling attacked, you might consider this an opportunity to learn about some of those things that were not covered in your school experience, and even to teach some of us what _we_ might not know.
Would you not like to know whether or not you are wasting your remaining time and energy in your silent corner? Some of the people that are responding to you have many years experience in these matters and could perhaps help you better to understand your chosen field of research. You have already learned some things about LEDs, and perhaps if you continue discussions here you will learn some other things about flywheels and energy storage vs. power output.
Why do you shy away from people who want you to define the terms you are using? What is "cold electricity", what is "radiant energy", according to _YOU_? We have all read the opinions and writings of Tesla, Bedini, Bearden and others on these matters. Perhaps you can explain, according to you, how "radiant" and/or "cold" electricity from the Bedini section survives being rectified by diodes and smoothed by large filtering capacitors to produce such an impression of brilliance in your LEDs. Do you not have confidence in your results? Would you not like to know exactly what is happening in your device?
Tanju
Quote from: TinselKoala on June 26, 2017, 11:30:34 AM
Could you please show your complete calculation working that results in your 650 watts output figure from your 33kg flywheel? Please be sure to include the "units" in your calculation so we can see exactly how you arrived at that figure.
Mass=33Kg
Radius=0.3 Meters
Rotation=200 RPM
Angular velocity=w=31.4 rad/sec
Angular Momentum= I=m*r2=2.97Kgm2
Kinetic Energy=0.5*I*w2=1464 Joules
Torque=Angular Acceleration* I
Power=Torque*W
Tanju
Quote from: Tanju on June 26, 2017, 11:48:42 AM
Mass=33Kg
Radius=0.3 Meters
Rotation=200 RPM
Power=Torque*W
Thanks for encouragement.
Let me correct the calculation this calculation was for 300 RPM which I was targetting to achieve. But at present ı am at 200 rpm angular velocity is less than 31.4
Quote from: Tanju on June 26, 2017, 12:01:22 PM
You have not shown your _calculation_, you are only showing input data and results. Let me remind you that Watts = Joules PER SECOND.
If you put a light load on your 200 rpm flywheel, what happens? If you put a heavy load on your flywheel, what happens? Clearly, the power in watts depends on the time during which that stored energy of 1464 Joules is dissipated.
You can only justify the large wattage figure if your flywheel remains running at that same constant angular velocity while you are continuously drawing the wattage from it.  Does it?
You will note that when the flywheel is running at a constant angular velocity, the angular _acceleration_ is zero. Hence the result of
Torque = Angular Acceleration * I
is ....  zero.
gotoluc
Dear Luc;
Thanks and regards
Tanju
Dear Tanju,
Please feel free to take leave at any time you wish as you own us nothing.
Building something just to have others dissect it is difficult. It's like seeing your own child's beliefs being questioned by a stranger.
I understand if you wish not to participate or need to take a break as it's a lot to take in when dealing with professional individuals like TinselKoala who has over 730 videos: https://www.youtube.com/user/TinselKoala  of builds and tests of different energy solutions and was professionally hired to evaluate many Free Energy Devices for decades.
Please take a little time off if you wish and or consider some of our test or experiment suggestions as we will be happy to help based on our own experiments and experience.
Kind regards
Luc
