Tom van Keulen coil v9 setup free open source
Started by indigo22, July 26, 2017, 07:19:54 PM
indigo22
hi Void,
no i want advanced students if you wanna show overunity and make it simple 4 everybody then goto the John Bedini schoolgirl model and built that, we are creating new coils that's my hobbie
8)
Void
Hi indigo22.
The fact that you did not answer my questions about the lightbulb, says it all.
You are obviously not interested at all in trying to explain to people what you are doing,
otherwise you would have answered the questions. I asked politely enough. :)
By the way. You were making a very obvious error when you said that the output
power for the setup in one of your videos was 220V x 0.06 Amps. You don't take
the nominal voltage for the lightbulb (220V) and use that to calculate the output power
being consumed by the lightbulb. :o You have to measure both the output RMS voltage
across the bulb and the output RMS current through the bulb to be able to determine the output power.  ;D
I watched several of your videos and if you are using a LED lightbulb, they can light up
fairly brightly with only low power, so all indications are it is not overunity. You would need
to know how to do proper measurements to be able to determine the output power to the bulb
with any accuracy, and when you are powering a bulb with a jagged pulse waveform as your
circuit seems to produce, being able to measure the output power being consumed by the bulb
can be quite tricky. Many people here have been at this sort of thing for many years, and some may
be willing to help you to learn how to do proper measurements if you ask politely, but from what I
saw from some of your very rude replies in this thread, I suspect that isn't likely going to happen.  ;)
People who have been looking into this area for quite some time see all sorts of claims of overunity here and
in videos on youtube, and probably at least 95% of the time the person making the claim either has little to no idea
of what they are talking about, or they are trying to pull a scam. Given this, if you want people here to
take you at all seriously, you first and foremost need to be polite and respectful with people, and be willing
to answer questions, and be open to constructive criticisms pointing out problems or potential problems
with your setup or your approach. If you can't do that, then it is actually you who is just wasting other people's time.  ???
If you want to share and discuss openly, then share and discuss openly. If you don't want to share openly, that's fine,
but you are definitely just wasting peoples' time here in that case.
Good luck with your experiments...
citfta
Quote from: indigo22 on August 04, 2017, 10:46:56 AM
hi Void,
8)
I have built several Bedini schoolgirl circuits.  I have also helped several dozen people get theirs to work when they had problems.  If you think there is OU in the schoolgird circuit you don't really understand how to do proper measurements because as interesting and educational as the Bedinin schoolgirl circuit is,  THERE IS NO OU THERE!  I have worked with that circuit for several years.  It is a very efficient circuit but it is not OU.  I have seen things that make me believe OU is possible.  Your circuit may be OU but without proper measurements as Void has pointed out there is no way to verify that.
Carroll
indigo22
to disreaspect my grand teatchere you f$%&(* ing as@#%$%^&le get the fuck outha here >:(
casiano
