Skinner 1939 gravity machine centrifugal force tests and hope
Started by norman6538, August 26, 2017, 08:16:20 AM
norman6538
I have been intreagued by the Skinner machine and so decided to look into what potential there is in harvesting the centrifugal force power. So I started by rotating a weight on and arm attached to a battery operated screwdriver.
And that simple experiment gave me hope because it could lift more weight than the weight on the arm's leverage could lift.
Since I did not know the work in from the screw driver I replaced it with a weight on a string to drive the rotation so I could know by weight and distance how much work in was required. And likewise I could know the work out but the lifted weight times the lifted distance.
I made the rotating arm so it could move back and forth like a seesaw so that it could lift a weight. So here are my current measurements.
I use nuts and washers for weights since they can be changed easily.
I drove the rotation via 3 nuts (5/16 inch) on a string. I lifted 4+  (5/16 inch nuts   4.66 units ). The driving weights dropped 3.125 inches for each revolution giving 9.375 units of work in. The lifted 4.66 unit of weight lifted 1.125 inches giving 5.245 units of work out but I only lifted weight on one side so with the other side it would be 10.485 units out.  That is almost
112% output.
Along the way I found that tweaking the speed/weight on the string and
tweaking the weight on the arm and the weight lifted gave various results.
So with my very crude device presented here I hope you can see this for yourself and maybe improve on what I did.
I believe that what Skinner did was to cascade his OU multiple times. So I theorize that if we had 1:2 ie 200% cascading would indeed give some very significant power.
Here are some referenced to the Skinner machine.
https://www.youtube.com/watch?v=mEat-8zOjlE  15 mins
https://www.youtube.com/watch?v=TTR9r5-sENc  Mario Gudec annimation
Published on Dec 25, 2015
being discussed here
http://www.energeticforum.com/renewable-energy/17195-william-f-skinner-1939-gravity-power-23.html
good stuff here....
http://www.energeticforum.com/renewable-energy/17195-william-f-skinner-1939-gravity-power.html
http://overunity.com/14655/1939-gravity-power-multiply-power-by-1200/msg430676/#msg430676
Attached is a photo of my crude work. I had a lot of fun making and tweaking this  from scratch in about 2 days.
I see hope that there is power in the centrifugal principle...
Norman
norman6538
Here is a little better photo that blocks out some of the extra things that are not part of the device.
Notice the clever u-joint that drives the device so that when the rotating
weight shifts left and right it still keeps turning. - very simple and effective.
The pivot is a 3/16 bolt at the bottom of the shifting wood and there are stops
half way up to limit its travel.
Norman
norman6538
There are 3 variables to change. 1. driving down weight, 2. lifted
weights, 3. rotation weights. And by adding rotation weight I got the
efficiency up to 120%.
I posted this because of its simplicity and crude and quick and dirty construction. I never waste a lot of time in a beautify  machine that
does not perform. I used soft iron bailing wire, string,  and clementine box
plywood and hot glue to hold things in place...
And I choose not to use measuring meters - just raw weight and distance
so there is no instrument calibration arguments.
So here is your chance to make OU in a day with the photo from this thread.
I only wish I understood how Skinner got 1200%. That might take another year or so.....my brain bursts come in spurts and this one has been a good burst in about 4 days.
Norman
seychelles
well when one listen to this utube one hears 1/8 hp motor power all his
whole work shop ,hacksaw, lathe..and that was done through this mechanical belt system..
Acca
Norman if you want help with the "Skinner" device only through private contact, I post here no more...Resident trolls will skin you to your bones and destroy you..
I will answer within 24 hours...
Acca..
ps Aron  has patents in mind and he is a shark after himself only, not to help anyone... at energetic forum.. look out..!
