Thanks to ALL for your help!!
Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
Dear Members,
See the attached link.
https://youtu.be/NTKw2Hp6tPw
Now I explain in simple words how it will work.
In the video you can see a seesaw having two ball each side .the red color ball side arm of seesaw is slightly heavier than green color side arm.the weight of each ball is 30 gram and weight of each box is 20 gram.
The red ball is a counterweight and green ball will work to create energy.
The green ball will be free to move but counterweight will be permanently mounted.
Now I explain:
When I lift up the arm of green color ball up to a certain height and then you can see the movement of ball in the video that ball is moving due to a slope .
But when I left the arm then the ball is getting back it's previous position or in other words the seesaw is getting back it's horizontal position due to overunity.
It is totally against physics laws as ,as per physics laws the seesaw shouldn't get back it's horizontal position but in the video you can see it clearly.
Now replace this ball with 10 kg.ball and counterweight 10.200 kg.and calculate input and output using potential energy formula.
In this mechanism don't think about input as input will be very minimal but think about output.
The movement of ball in the box will work as a output so the length of arm and length of box will be also important.
The ball mass=10 kg.
The length of arm is=1 meter
The length of box is=80 cm.
The width will be depend on the diameter of ball.
Now calculations:
Input is very minimal
Output if a 10 kg ball will be rolled down from 10 cm height(though the height will be more) than using potential energy formula
10*10*.10=10 joule
So the output will be 10 joule but input will be very minimal.
I would like to insist on some following points.
(1)the angle of box will be 120 degree downside(see the Sketch)
(2) two piston generator will be mounted on the sidewall of the box.
If still you have any doubts then pls tell me.
(3)there is overunity in this mechanism otherwise seesaw wouldn't get back it's horizontal position.
I request you that if you any doubt regarding to understanding then pls tell me as I am ready to clear your all doubts.
Vikram Kumar Gupta
profitis
"as per physics
position but in the video you can see it clearly"
Its getting a free ride?
vikram_gupta11
The most important point is in this mechanism we can increase the potential energy of the ball as per our desire by doing some changes in the design of box.and yes in other words the potential energy is the most important and if it is increasing after applying minimal input then the output will be more than input.
I have already sent you a video.it is not a big hurdle to increase the potential energy in this mechanism.
The green ball will move between piston generators and will hit these generator .when the ball hit the generator then in response generator will work to hit it back and this will be an advantage in this mechanism.
There is nothing to think more and more in this mechanism as we are increasing potential energy by using minimal input.
There are only three points.
(1) the input is very minimal to lift a heavy mass(10kg)
(2) we can increase potential energy of 10 kg.mass using minimal input. (3) the seesaw is getting back it's initial position without using any extra energy. If these points works in a system then no physics can prevent it to get OVERUNITY
vikram_gupta11
See the link
https://youtu.be/9yQ9Ln7jBQ8
In the video the potential energy is being increased of the ball using minimal energy but after getting a certain height it will fall down and get back it's initial position due to the unique design of seesaw without any extra energy.
The design ,as per sketch,of box will work to hold the ball.
vikram_gupta11
Some research scientist from Kharkiv Polytechnic institute has approved it.
