Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
I increased the weight of upper tube and at first I am releasing the device.
The device is getting more than 180 degree.
But it is not getting back 180 degree.
But when I release the weight then it is getting 180 degree.
https://youtu.be/WoubwuRco6I
MAIN PROBLEM:
It is ready to getting back more than 180 degree but only problem is lack of latch as weight is dragging down the device due to reverse falling down.
Once latch mechanism attached then ,no doubt,it will work.
The weight was luckily got stuck when I did first attempt and didn't fall down reversely.so it is clearly showing that there is need of latch in it.
Low-Q
I think (Rather know) the problem is how you're suppose to make that weight reset its position so it can fall down again. As you said, when the weight falls down, the pendulum moves beyond 180°, but not on its way back - due to lack of a working latch. I can't under any circumstances see how you're suppose to pull this off without spending your hands energy to initiate the first and next coming drops of that weight.
You have to look at this in a very simple way:
The weight must reach a higher level without putting energy in to do so. Without a higher level, and then more potential energy into the weight for each cycle, you have a dead device that isn't capable of sustaining its motion, and possibly be able to deliver useful work without stopping.
Vidar
vikram_gupta11
See the video.the weight or arm is getting back its initial position.
https://youtu.be/erAEKdJErsw
I am releasing it like a pendulum but we all know that a pendulum cannot get back it's initial position after releasing from a point.
But in this mechanism the pendulum is getting back its initial position because of potential explosion of free falling of weight.
But when the weight is not falling down to then it is not getting it's initial position.
There is need of latch mechanism to hold the weight and no doubt it will work.
I do some changes in it.a bearing and mount it on a rigid foot and the pendulum will get back more height than the initial position.
All mathematics is supporting overunity in this mechanism.
I will present a second video very soon.
vikram_gupta11
The weight is falling down twicely in this mechanism and again getting back its initial position.
I fix a bearing and mount it on a rigid foot and the device will get back more height than the initial position.
vikram_gupta11
As per sketch I did some work and got success .
The arm is getting more than 180 degree after releasing the ball and again getting back more then previous height.
In each cycle the height of arm is getting more and more and it is clearly proving overunity.
Soon I will present a video.
