Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
Dear Sir,
Each time center of gravity will be not changed due to counterweight.
Seethe sketch.as per sketch the arm length is 2 meter.a 2 meter long tube is mounted on the right side arm in middle.
A 10 kg ball is in rest position and a " latch pin" will work to hold the ball.the latch pin will work in this way that the ball will fall down as per our desire.counterweight is 16 kg.so now total weight of device is 26 kg.
There will be two lock system which will work to lock and unlock the device.
: The device will be in rest position as per Left side sketch.once ball falls down then it will turn like right side sketch.
: The wonder is that if the device's initial position is as per Left side sketch then there will be need of lifting uup the device only 1 cm.
: So now input will be only 2.6 Joule but output will be 200 Joule as ball is falling down from 2 meter height.
After falling down the device will be positioned like left sketch and there will be again need of just 2.6 Joule energy.
So input will be 2.6 Joule +1 Joule for lock mechanism.
Input=3.6 Joule
Now you will say that we will have to apply 3.6 Joule energy from outsource.
But not as you are forgetting that the ball has been stopped after transferring it's energy to a piston generator and this piston generator will work to generate energy to tilt the device again and again.
Though it will be a Oscillating device but main purpose is to get more output than input or overunity.
vikram_gupta11
The impact energy of ball will do two work.
First it will provide momentum through pushing the piston generator and second the generator will work to generate energy due to kinetic energy of ball.
vikram_gupta11
There are no issues like friction,heat air resistance in this mechanism as input is minimal and output is far greater in first effort.if first effort is providing overunity then it doesn't matter that it is Oscillating .
In this mechanism the ball is working to get overunity not the whole device.
sm0ky2
Trying to simplify this so the math is more straightforward
Let us have a pendulum of the counterweight
So it hangs at bottom.
And the tube is to sit exactly at the pivot for the ball.
So that any motion left or right changes the ball
If there is extra energy, the ball will keep the pendulum moving.
and pendulum, in turn keeps the ball falling, tick-tock like a
self-powered clock.
vikram_gupta11
Dear Sm0ky2 Sir,
You are correct it is like a self powered clock but what about input as input is very minimal(3.6 Joule) and kinetic energy of ball is 200 Joule.
There is a big difference between input and output.
As far as I think there is no need of calculating the energy at construction time .so we can get output as per our desire.
The device is getting back its initial position again so again input is 3.6 Joule and output 200 Joule.
We will have to extract impact energy of falling ball using generator .so the device will oscillate forever without extra energy.
Please reconsider it.
