Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
sm0ky2
I get what you are saying, and can see/feel the momentum
But won't this be absorbed by compressing the spring?
falling ball compresses spring, spring pushes the ball back up
our 25 J is (partially) returned to us when it resets
But we have to put 25 J more do go another cycle.
So we lose part of the 25 J each time.
Like in your video, when you use your hand to lift it up.
sm0ky2
It is a very strange way to transfer gravitational potential into momentum
But in experiments I am not able to achieve excess power, greater than the input.
I'm really curious now how a Chaos-Pendulum would perform,
if the weights were in tubes......
vikram_gupta11
Dear Sir,
We will have to use the absorbed energy in the spring to tilt the device.if we could use this absorbed energy then there will be no need of extra energy to tilt it  and device will sustain it's momentum.
sm0ky2
Quote from: vikram_gupta11 on February 01, 2018, 11:11:41 AM
Dear Sir,
Even if we perfectly balance momentum and springs
There is still friction and wind resistance.
even though the total change in (mgh) =0
I think it is the same as just spinning a wheel
It just seems mathematically confusing.
I was incorrect by using the wheel analysis
To use that, the weights must revolve a full circle
around the axis.
The lever analysis gives the correct answer.
Change in E is -
sm0ky2
Each time the ball moves, the center of gravity changes
