Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
Quote from: lltfdaniel1 on October 20, 2017, 01:30:50 PM
The way the heat pump gets hotter to no end in potential is indeed breaking the law of conversion and should be cut off but doesn't regarding the design of heat pump in your fridge that is.
Just like a self running solar panel but done with the heat pump simple to understand and is achievable.
Solutions like the heat pump can be unlocked and used to fully defeat the conversion law to it's fullest.
This zero point force if you can call it a force, is lame. Radiant energy is incompatible energy and like positive and negative following each other, well with zpe being incompatible doesn't follow positive zero point is a negative energy so there must be a positive one outside of the box.
So if you want to think out of the box well it would be hard, i'd start with nature and look closely at nature.
The accelerator effect breaks the law of conversion fully as well and that is present in earth/nature.
Like viewing it as to how to get past flux gates and the like.
View accelerator effect like a magnet motor or gravity motor using very simple physics.
As well as translating electron spin into movement the using very simple physics.
[size=78%] [/size]
Don't let lost in the world of conversion. this is an incompatible force.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
Due to how dangerous this is i have deleted what i previously have said.
E.t would prefer not to have its energy harvested only to be destoryed.
It would cause e.t to intervene .
It would leave e.t with no solution as how to solve the problem of it's energy being destroyed but to destroy the person who caused it.
They value their positive vacuum energy incredibly a lot.
zpe energy is already destoryed energy so i have removed my idea.
Anyways sub-traction method to work out about the power to destory regarding octaves.
lltfdaniel1
Regarding the accelerator effect the wave fluctuates giving excess power.
This fluctuate is the potential of giving excess power.
When it breaks the threshold it fluctuates.
edit
They have accepted my accelerator effect explanation and is now going to be implemented in college or university after all being slap with conversion law in my face this is a slap back then.
Anyways if you want to extract energy from vaccum (negative) then you have to activate the perpetual process in the vaccum done with the positive vaccum which is incompatible still but will work via absorbing the energy and the perpetual effect wakes up and is unlocked(activates) in the negative vaccum called zero point.
At present the perpetual effect likes dormant in zero point energy and needs the positive vacuum to activate and work.
Zero point energy has tgo use repulsion effect of both ends of the spectrum and both being negative (as opposed to having postive and negative in a power socket we all use) as zero point energy is fully negative energy and it will attract energy from positve vaccum but this will destory energy from positive vaccum.
Zero point has an opposite equivalent and that is true if you were to do this it would create a parallel path effect
I am thinking of accelerator effect to active perpetual force in zero point to work.
To achieve this it has to be same process where you spilt the atom it takes two negative forces to spilt the atom.
lltfdaniel1
Quote from: lltfdaniel1 on October 22, 2017, 05:13:34 AM
edit
So yeah if you cans see about extracting energy from negative zero point then zero point it self needs to extract energy for that as well then.
Zero point cannot self generate/perpetual what so ever, it zero point has to get energy from somewhere as well and all roads lead to zero point, it is the backbone of the energy world.
Then you say where is the energy coming from, and you say ney it comes from the positive completely opposite incompatible positive equivalent of the vacuum.
zpe is a leeching force
Zpe is a force with laws whereas the opposite equivalent has no laws.
We would all be dead if we fully use zero point energy, we have positive incompatible vacuum equivalent already present in our electric circuits.
If zero point was self generating we would all have free energy but isn't so i am right about zero point energy.
The unlocking effect of getting past laws comes from positive vaccum and the example is bypassing lenz law/conversion law which you can do yeah?
It comes from positive vaccum you know you cannot extract energy if when lenz law and conversion are in full effect so you get my point?
Like tapping into energy which you can do, this is coming from positve incompatible vaccum which enables you to do this which i know.
Should be obvious to you that zero point is incompatible with positive vaccum energy entire opposites one is all about laws (zpe) and the other has no laws which can bypass zpe laws.
When you break over cop 1 you will hit a brick wall regarding the conversion law so if you can bypass cop 1 you are breaking the rules of physics done via opposite positive equivalent of the vacuum
I hope that makes sence.
antigrav89
IMO, the ambiguity about overunity comes from the way energy efficiency ratio is defined.
In the case of electric circuits, we usually define it as the ratio of the output power to the input power, measured in the electric circuit.
But we should rather define it as the ratio of the useful output electric power to the absorbed power, the absorbed power having two origins: the input electrical power and the energy transfered from the active vacuum medium to the system (considered as a open system from the thermodynamic point of view i.e. able to exchange matter and energy with the outside environment).
To achieve energy conversions between the vacuum and the system, the vacuum must be described as a dynamical system possibly modeled as an infinite fluid. This fluid has to be compressible to allow waves to propagate with finite speed (as sound in air) and inviscid (non viscous) for not dissipating thermal energy. In this scheme, particles of matter have finite sizes and appear as stationary vortices. In the normal conditions, vacuum energy is uniformly distributed and matter continuously receives energy from the vacuum and radiates the same quantity of energy (so the mean energy balance is null). So, if this equilibrium is broken, energy has to flow to restore equilibrium. If this non-equilibrium state is maintained, a stationary current can be established.  If we consider the vacuum as a compressible fluid, its density can vary. So, if we are able to create a stationary vacuum energy density gradient, a energy current can be created between the system and the vacuum. Scalar wave solution of Maxwell equations allows non electromagnetic energy to propagate.
The main problem to solve is how to convert this energy into a coherent electromagnetic energy to create an electric current.
This involves that vacuum fluctuations (considered as electron-positron virtual pairs) must be stabilized to allow either the separation between electron and positron charges or the creation of superconducting pairs. The Big Bang theory tells us that such a charge separation is possible, because, assuming that matter emerged from vacuum energy fluctuations consisting of matter-antimatter pairs, matter and antimatter should be present in equal quantities and we should not exist. Several hypotheses might explain this unbalance state:  matter and anti-matter were (very) swiftly separated before mutually annihilating (but where is the anti-matter now?) or a part of anti-matter was converted into matter. Electric circuits where free energy is observed are generally composed of coils, capacitors and magnets (permanent or electromagnets) and the source of energy excess is often attributed to the magnets. Recent studies of magnetic materials that showed there exist numerous interesting interactions between electric current, spin current and the crystal lattice magnetic spins to create magnetic structures such as skyrmions might provide a further insight into ways of understanding how matter and energy interact in magnets.
