Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
NickZ
   Bulbs will light using magnetic current, but the voltmeter won't register the voltage when the frequency is beyond it's limits.
   If a scope were used, there would be a voltage reading at the bulb. Most of us know about this. But to say that there is NO voltage reading, zero, and therefore, there is NO voltage at the bulb, is wrong. There is voltage, or the bulb would not light, as Hoppy mentioned. We know there is voltage, the question is what do the readings on a scope show, and what is the amperage, so that the output can be figured. Otherwise, talk of zero voltage, is not correct, nor zero readings.
gyulasun
Quote from: rickfriedrich on July 06, 2019, 09:48:33 PM
If Itsu had been to my meetings and then replicated the same, then what would you say to that?
Honestly Rick, would you let anyone measure anything relevant to your resonant kit setup on such a meeting?
Would you let Itsu attempt looping back the outputs to replace the power supply? It could be done within 1 hour
work by using full wave diode bridges across the LC tanks of the 10 or 11 big receiver units (as per your thoughtful
calculations the many small receiver units would not be needed) and collect the DC outputs in a bigger puffer capacitor.
This latter then would feed the gate driver IC directly, provided the DC level holds up in the puffer capacitor at least for
some seconds (and hopefully for much longer),  that would already indicate the real strength of the received 8W power
you claim. This way the participants on that particular meeting, say 8-10 people (or even 18), could see the performance
in the real world.
(The function generator could still be run from its own supply because the input of the gate driver needs only a few mW
drive level, negligible to the claimed 8 W output. And a discrete square wave generator can be built for the job.)
I hope those participants you mentioned "as a good number of them reading this thread" have been indeed reading
this post too and next time they will 'demand' the loop back attempt...   8)
My kind message for them: Folks, electric power going into LED bulbs cannot be evaluated numerically by the naked eye,
LED bulbs are strongly nonlinear devices. Please see this post here and think the spectacular LED brightnesses over:
https://overunity.com/17491/confirmation-of-ou-devices-and-claims/msg534508/#msg534508
And no offense but I would believe Itsu 100% what he would have experienced if he had been either a witness there,
or if after seeing it he would replicate it and show it in his video: I would certainly believe him. Many members
(who care to follow his activity) have known him for years here and on other forums.
And why Itsu would report back a false result after his succesful replication ??  I would trust him 100% and so would
several other members here too.
For he would have learned from you a wonderful circuit setup...  and the other participants present in the real world too.
And I would really be happy that the 8 W (or even only say 4 W) is indeed present at the outputs of the satellite LC circuits
while less than 1 W is consumed from the 8 W (or 4 W) output to maintain operation. Rick I would acknowledge I was wrong.
Gyula
NickZ
    Guys:
   I'll second that... I would also trust itsu's findings, 100%. Regardless of the test results, being good or bad. Anyone can be wrong, but he tells and shows it how it is. Whether it's positive results, or not so positive results.  But, the proof is in the pudding, and lighting just a 10w bulb, as well as a feed back path, would help to turn the tide, for me.
   I would trust what certain people show in their videos. Not all devices are faked, just mostly... and that is why we are all so skeptical about what some people say, and what they show. Any OU type of claims need to be verified, that is what this thread is here for. Rick told me to put up or shut up, when I bring up the subject of proof. I guess he forgot where he's at.
   We are here to learn... All of us. Without long drawn out sermons, telling us how and what to believe. Thanks, but I got that one down, already. Waiting for the real self runner...before diving in, to unknown waters.
Void
Quote from: rickfriedrich on July 02, 2019, 06:00:25 PM
Many thousands of people already have OU...
So many liars and delusionals in this world. Very sad.
overcurrent
I don't know, it is something I have wondered for a long time. Are they all liars Tesla, Morray, Newman, Meyers, Searl, Wagner, Hans Coeler and the list goes on and some as Searl and Meyers have done jail time but does that mean they were all liars or is there a true conspiracy to keep it all under wraps or is it human greed I don't know for sure yet after 15 years of looking into this stuff. This is part of why I don't even experiment with some things such as energy from the sky or ground because what if you did figure it out and powered your house from the ground do you really think you wouldn't just be thrown in jail for stealing power.
