Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
poynt99
Quote from: a.king21 on July 26, 2019, 12:54:01 PM
Well I see that you are happy now that Rick has gone.
No one is happy about any aspect of this type of recurring debacle, including Rick leaving. And this includes Rick's poor attitude and over-reaction to relevant, honest questions.
Could YOU show us the way to overunity please........
I would not be using such words unless I was 100% certain of my stance... are you? Would you (or Rick for that matter) bet your house that Rick has OU devices? Of course you wouldn't, because you are not 100% certain, and neither is Rick.
And that is one primary reason why these forums are here; to share, discuss, evaluate, and test people's ideas, and in doing so everyone learns something. One day perhaps we'll even discover true OU. But none of this can happen when folks have such poor attitudes, and/or are simply trying to sell kits, claiming the sorts of things Rick was claiming with his coils.
Then there's the all-too-often encountered "Dunning-Kruger effect", but I am not going to go there...
seaad, why "5000 Watt " and how : as Wattpeak or Wh per day ?
WhatsIsIt : how important is for the speed the " frequency modulation" ?
Mr.Friedrich wrote about motor use : capacitive,resistive,inductive load ( and inrush current/ nominal current ratio)
When 50 Hz represents 3000 rpm rotative and 60 Hz 3600 rpmhow many rotations represent KHz,MHz signal cycles ?
What is BEMF in grid- connected appliances : look for negative power factor
WhatIsIt
Quote from: Vortex1 on July 26, 2019, 04:18:26 PM
You are right on It is good to see someone telling the real story about how to switch rapidly and other points you made.
From reading your posts, you are obviously well versed in the art,
But it us frustrating to deal with, or try to teach "the man of the hour".
Sometimes fancy knowledge discourage members up to the point they give up because they think they know less.
It is not true. We are all here in same pot.
Even SG3525, IR2110. IRF 740 basic setup on/of 30/20 ns outperforms any Ricks mosfets he has on his web sale. And it cost peanuts.
I dont want to talk about Rick anymore.
Members of this forum has to unite and share.
When sharing, something always pops up. Thats the point. You need nobody.
And you have everything. Just become all friends and work together.
Nick Z is trying that for a long time.
He does his thing and not depend on some messiah.
I am trying to be fair for anyone. Smallest and biggest. As much as I can.
Can stand critics also if I am wrong.
I am small guy just as everyone else. No big deal!
Dont be frustrated, you all are doing good!
The truth will pop up, if not today, then some other day. It will!
WhatIsIt
Quote from: lancaIV on July 26, 2019, 04:38:24 PM
Hehe, ok.
Something normal in AC is reactive power. It reflects from consumer inductive and capacitive load back to power companies generators overloading them.
Simpliest form of dealing with reactive power in AC is capacitor (of certain value) per motor, inductive load.
Also, power companies uses big motors/generators for compensation of the whole grid at once.
Rick is transforming DC to AC with his pulsed motor and use same to absorb reactive power from load, making motor a generator, and result with additional torque, making more power for load which reflects more reactive power back to motor/generator.
Balance between load and motor makes reactive power to power motor, so battery does not have to push much, while it powers load. Load has to be inductive or capacitive nature to achieve that.
He did not invent this. This exist for a long time.
Google how electric companies make battles with AC reactive power and it will be clear to you. They use big motor/generators for balance of grid power. Very expensive solutions for large grids.
Which makes some of Rick statements true.
It is foggy does he understand this.
He does not know how to use voltage/current probe for math power measuring, so it is not clear how much he understand of the whole thing.
As for power in W. Million volts does not mean 5000W. It depends how much current that million volts has.
If you use bipolar transistors you will never see effects which mosfets produce. Thats speed.
You just have to try both and compare. Once you do, you will love mosfets!
WhatIsIt
Is the usage of reactive power OU.?
NO!
It can reduce power consumption, but it is not OU!
