Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
Void
Quote from: Jeg on November 17, 2017, 04:18:55 PM
Never played with Bedini ideas. What triggered me with this replication is that it combines  many forms of energy, and looks possible to transform them in a constructive way so to counteract the Lenz effect.
Hi Jeg. Yes, battery pulse charging aside, it would seem that there still has to be something quite unusual
going on to charge up a fairly large cap bank to a fairly high voltage in a short enough amount of time
without consuming too much power to do it. I guess that may be why a motor and flywheel
and special energizer combination is used, and may well be why John Bedini spent so much time
experimenting with that kind of setup.
All the best...
Void
In case this is of use to anyone here, I did a quick test to see what the
current waveform looks like when discharging a 5300uF (3300uF + 2000uf)
cap bank charged to 24V into a small 12V 5AH Sealed Lead Acid (SLA) battery.
I wanted to see what kind of current spike waveform I get from that arrangement.
I used a clamp current probe over the wire to measure the current waveform.
My SLA battery was sitting at about 13.1V. I just used some test leads to connect
things together in this quick test setup, so there is probably a little extra
resistance in there skewing the results a bit. With thicker wires and everything
connected really solidly, the current might well peak a little higher and be of a
shorter duration.
A 5300uF cap bank charged to 24V = 1.5 Joules
When it is discharged to 13.1V, it has 0.455 Joules remaining in it.
That means that for each discharge of the cap at 24V into the battery, about
1 Joule of energy will get transferred into the battery. How much of that 1 Joule of
energy the battery can actually absorb with each discharge pulse is another matter...
It looks like the cap discharge current pulse peaked at about 17.4A, and the
current pulse lasted about 10ms. Not sure why the current pulse was squared
off a bit at the top. I think this should be a close enough representation though.
tinman
Quote from: Void on November 17, 2017, 06:12:27 PM
shorter duration.
Thanks for doing that test Void--much appreciated
I think the point I've been trying to make is that virtually all replications will still allow the excuse of "not exact enough" when/if they are found not to meet the OU claims of the originator.
But if someone can get their hands on an original unit, that once was claimed to be OU by the Builder Himself, even that might not remove all possibility of the "not close enough" excuse -- as local conditions may vary, or any of a number of other factors not directly associated with the build itself.
Void, that little flat spot has me thinking. Could it be an artefact of the probe you used? Out of range, signal truncation? I wonder if a good noninductive CSR would show the same flat top. It might be interesting to try both your current probe and a CSR on the same pulse.
AlienGrey
Thanks for the jokes fellers  ;D
Who is going to hand in a working device ? it just won't happen, not to mention the problems to the system and the relief of the earth environmental change and then there is greed.
Lets make a start eh! with word, what word 'electric' or 'electricity' oh we keep coming back to the word, what word ?
This word is 'ELECTRON' and what it produces and what does it produce ?  MAGNETISM and what does that do ? slows everything down to the speed of light.
What happens if you dump the electron, what have you got ?
come on !
