Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
Gear
Rick,
One more thing!
I trust what Mr. Itsu, Mr. Tinsel, Mr. Void and Mr. NickZ are showing me over the internet.
I dont trust your videos and statements.
Thats my choice and main only.
You can write novels if you want and it will not change a thing.
Start behaive like researcher and maybe, just maybe you can catch with them.
Start use your instruments and scope, that will help you.
If you dont know how to use your scope for transient purposes, dont be affraid and ask them.
Your level of knowledge is very foggy.
And when you start to use transient math, then you will see your mistakes, not before!
Again, this is not insult. You have 100+ pages of claims. Time to support them with evidence!
Dont you agree?
If you not, go f...,. yourself!
baudirenergie
Very nice. I was blind, but had hope that all this Videos from Rick ends in positive results. It is a barrier for people, that only would greedy grasp something without want to invest some time. That informations are not good for rough people, I think. I can see it on your last comment to Rick..wow!
Why did you make a big deal about measurement. It is very easy to do it very accurate via Watt hour meter (sorry, don't know the correct word in english, it is a DC Watt hour measurement Tool).
First you load your primary battery to maximum and unload it over the Wh-Meter. Now, you know your Wh in your battery or battery bank. Reload it to the same Cutoff Voltage and start your system. All other batteries (for example secondary battery bank) should be completly empty.
After your run you can unload all batteries in your system over the Wh-Meter and can prove for yourself, if your system is over- or underunity. Simply compare the total Wh after your run with the total Wh that you have measured before.
Quote from: Gear on July 29, 2019, 04:03:19 PM
Rick does not measure anything. He just quessing power of his circuits.
Where you saw that Rick measuring voltage and current on scope and make a math for power.???
Mr. Itsu does that all the time and showing power. Real transient power.
And Mr. Tinsel is right. If zero current is source, then the source is not needed or small cap will does the job.
This thread is joke of ignorance!
Are you blind?
WhatIsIt
Quote from: baudirenergie on July 29, 2019, 04:38:10 PM
Very nice. I was blind, but had hope that all this Videos from Rick ends in positive results. It is a barrier for people, that only greedy grasp something without do invest some time.
Why did you make a big deal about measurement. It is very easzy to do it very accurate via Watt hour meter (sorry, don't know the correct word in english, it is a DC Watt hour measurement Tool).
First you load your primary battery to maximum and unload it over the Wh-Meter. Now, you know your Wh in your battery ory battery bank. Reload it to the same Cutoff Voltage and start your system. All other batteriess (for example secondary battery bank) should be completly empty.
After your run you can unload all batteries in your sytem over the wh-Meter and can prove for yourself, if your system is over- or underunity. Simply compare the total Wh after your run with the Wh that you have measured before.
You must be aware that batteries can chemically produce current when they are under rated voltage or depleted.
Only capacitors can show true situation like Mr. Itsu did. He understood problem.
And he used supercaps.
You will be fooled with batteries.
Dont use batteries to.prove OU. Use capacitors of big capacitance, supercaps.
Why dont you do it and show to everyone OU? Why ask Mr. Gear to do it? Hmm?
Is that the same thing Rick does?
Envolve everyone to solve things for him?
Please do it, take a measurements and come back with results?
Dont take Ricks path of stating and doing nothing!
Thats the worst path!
citfta
Quote from: baudirenergie on July 29, 2019, 03:46:05 PM
You are convinced from Void post but criticize Ricks measurement. Ich have never seen such a flat discharge curve of his statistic in real life. It is simply impossible.
His Videos are made, that you can understand the process that give you gains. You have to replicate it for your own. This Videos are not made to prove anything, only give help for free. If you don't want this information, why you watch it?
99% of you are convinced that Ricks measurements are false. Everyone has confirmed each other in every negative claim about him. Why you are posting this things again and again?  I tell you something: Perhaps you feel there is more there. A big truth. And no one should find it? That is the reason, why you are all came in here and prevent a constructive discussion about that topic. I know it, aking knows it and also the whole hole silence readers, that cracked the code.
The problem is that Rick NEVER makes any real measurements.  All he makes are excuses for why he doesn't make measurements.  A flat discharge curve from a battery doesn't mean anything if you don't know the amount of current being drawn from the battery.  If a battery has been fully charged and then allowed to rest for a few hours and then lightly loaded it will actually show an increase in voltage for the first few minutes because as the battery is first being used it will warm up slightly and that will increase the voltage.  Many inexperienced experimenters are fooled by this.
You are criticizing people that have been working in electronics for many many years.  They have put thousands of hours into investigating claims like Rick's.  Unless Rick is willing to share more than he has there just isn't any way to verify his claims.
Respectfully,
Carroll
WhatIsIt
Mr. Gear,
I like your thinking. Sharp. It introduced some clearance into the mist in this thread.
If I can ask, I can see that you understand things. Is it professional?
You do this kind of things?
Just curious, you dont have to answer.
