Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
Void
Really all Rick has to do is follow through with what he claimed in his video, and take the output from
one or more of his coils and use that to try to power his generator circuit in a closed loop. No need for a battery
if you do that. Just charging up a large filter capacitor at the input should work. I think the reason that Rick doesn't
attempt this and instead makes excuses is because, as we all should know, the chances are very high it will not actually
work (not actually COP > 1).
If his setup really is showing a significant COP > 1, as has been implied, then this should be a relatively easy
thing to demonstrate. As I have pointed out, lighting 12V LED lights connected directly to a 12V battery is already
essentially 100% efficiency, so Rick's circuit is pointless unless it produces a COP > 1.
All the best...
hartiberlin
Quote from: Gear on July 29, 2019, 05:29:01 PM
You are good guy and trust too much. In every circuit you must measure input power and load power.
Otherwise you will be misslead into falxe thing.
I wont go into deep of topic. Lots of guys here done it and saw mistakes.
Nobody here is telling you that as a joke. They also been misslead many times and learned the lesson.
Measure input, output, thats the only way.
Dont trust nobody until you do your measurements.
Most realible measurement is transient one. You must have scope, voltage and current probe and ability to make math on scope.
Every other method sometimes can lead to nowhere.
There is no magic negative power which feeds lots of load. No. You measure how much your load consume. That is correct way.
Always measure! It will also show your mistakes as well!
I dont mean to discourage you.! Always take the measures the proper way!
Sorry to dissapoint you about Rick.
Have you replicated it yourself with the original parts from Rick and replicated it ???
My friend has and has got the same results as Rick ! lol...So far regarding the measurements...You are just a skeptic, that has probably never done any good measurements yourself..
Regards, Stefan.
hartiberlin
Quote from: gyulasun on July 29, 2019, 05:47:51 PM
But Stefan, Rick clearly stated :
So he claimed COP > 10 performance between the resonant TX and RX circuits.
Gyula
So Gyula,even better, then we get 10 times running time out of the batteries ! Yes, that can be possible...My friend will show soon his replication...
Void
Quote from: hartiberlin on July 30, 2019, 06:44:27 PM
Regards, Stefan.
Hi Stefan. If your friend got the same results as Rick showed, then that is not so good.
Rick did not show anything at all convincing, as has been pointed out already.
Try powering some non-inductive resistors or incandescent bulbs of at least 5 Watts rating,
or better yet self loop it as Rick claimed in one of his videos should work. I would really like to
see an honest attempt by Rick or your friend to self loop the setup. Keep in mind that if I power
12V Lights directly with a 12V battery, that the efficiency is effectively 100%. There is no point to
Rick's circuit if it is not COP > 1.
All the best...
WhatIsIt
Quote from: rickfriedrich on July 30, 2019, 02:31:15 PM
. You are really interested in suppressing this idea I see, just look at all your postings all of a sudden. Filled a whole page with nothing at all. It really gets under your skin.
I am not suppressing you!
I am encouraging you to measure it properly and tell the world you are right!
They all expect that from you.
And whole world is waiting for you to do that after 115 pages of claims.
So , it is up to you, not on me.
