Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
hartiberlin
Quote from: WhatIsIt on July 30, 2019, 03:47:35 PM
Stefan,
Please, remove moderations from Gear.
I am trying to convince him to help, and he is half willing to do it.
He has army of people and SF tech behind him.
He was maybe rude at the times but he is great asset.
It is not goal to disprove Rick. Goal is to improve what he does if it is possible.
Your choice!
Thanks!
User Gear only made also rude comments....
As I said, I will moderate all users, who just flame Rick now...
So I can better see, what they have posted and let it through and directly answer their postings or delete then,
if their is no technical data in it and they only flame...
I guess this is the only way to keep this topic going now without too much nonsense claimed over here and flamed...
WhatIsIt
Quote from: hartiberlin on July 30, 2019, 07:01:11 PM
Sure I undertand this, if his LED lights light then only due to the RF bursts only with maybe half of the rated output power,but he can connect several LEDs like 10 x 3 Watts LEDs and they shine at maybe 1.5  Watts each and you can run these LED bulbs for 10 timeslonger on the same battery with his circuit, than a single 3 Watts LED at full 3 Watts output, that would have generated then15 Watts x 10 times longer...
It seems the batteries are required in these circuits as they play an important role, so you just can´t run the circuit just on supercaps...
Maybe the energy is directly converted from inside the battery then...
This is, what we still have to find out...Regards, Stefan.
Stefan,
Rick has to unterstand that nobody is against him.
But he must start to participate.
What you suggest to do next? Continue without measuring?
Just build the thing without knowing what is really happening and how  much we can pull from that system? And if we can pull more than we put in?
Because we can not find common point, can you be the one and make some decisions as neutral person.????
Suggest next steps?
Make some rules?
hartiberlin
Quote from: Void on July 30, 2019, 06:50:34 PM
Hi Stefan. If your friend got the same results as Rick showed, then that is not so good.
Rick did not show anything at all convincing, as has been pointed out already.
Try powering some non-inductive resistors or incandescent bulbs of at least 5 Watts rating,
or better yet self loop it as Rick claimed in one of his videos should work. I would really like to
see an honest attempt by Rick or your friend to self loop the setup. Keep in mind that if I power
12V Lights directly with a 12V battery, that the efficiency is effectively 100%. There is no point to
Rick's circuit if it is not COP > 1.
All the best...
It seems these battery circuits need the batteries ! Maybe the additional extracted energy is generated inside the battery cells...
So closing the loop without the batteries is not possible...
So if you charge up a 12 Volts battery with 80 Wattshours and you will get out of it with Rick circuit   160  Wattshours, what do you call this ??
Some people call it OU , some call it better efficiency out of batteries...lol...
hartiberlin
Quote from: WhatIsIt on July 30, 2019, 07:21:10 PM
Stefan,
Because we can not find common point, can you be the one and make some decisions as neutral person. ??? ?
Suggest next steps?
Make some rules?
Have you built it ?
My friend has..and so has Rick..
So when my friend is ready with his new parts we will show it...
You just keep on flaming here... and you don´t add any technical details or analysis yourself.... so you keep being moderated, so I can much better answer...
Void
Quote from: hartiberlin on July 30, 2019, 07:27:06 PM
Hi Stefan. Ok on possibly needing a battery in there. I would suggest to try it with 3 Watt
incandescent bulbs instead. If the bulbs are really consuming about 1 Watt or more, then it
should work with 3 Watt incandescent bulbs as well. Would you agree? I posted a web link above for a website
which sells 3 Watt incandescent bulbs, if you can't find them locally.
All the best...
