Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
ramset
Now you show a bit more of your loving self ...sorry I have very Bad problems with Visionand seeing the screen ..[Eye Buckle surgeries and Retina detachments, it takes a very long time for me to write ,having to go Back and forth to correct ,I was unaware of this problem with spacing.
that and on this site my Keyboard does not put what I type and how I type
on the page [sentence structure and spacing],I have mentioned this many times here...when I use the phone and talk Type it seems better but even harder to see the screen..[below is a sceenshot of what this post looked like when I pressed send ,and here you can see how it looks.[EDIT this screenshot is after posting a good post and having to go back 20 times to try to make it readable here.
I am amazed that you write Liable here against a Known Man implying an act of deception.
and it would be a mute point if many could replicate your simple circuit
and show a gain mechanism here for others to see
also we have the option here of using a Lab that has a volunteerwho could replicate this gain ?
The Lab in Orlando that helps people here and elsewhere search for technologies to share with the world  some here would send all the pieces there to be assembled
and shared.
for clarity you are saying there is a gain which will manifest in the lab ..or we can Hire a lab to investigate ,
I have worked with test labs all my working life..there are plenty who could do a 3rd party certified report .and post the results here,their  reputations are on the line every time they write and certify a report
we are after all talking about saving millions of lives here ...with Your technology ...and some would say it will save our planet too.
Thanks Grandma
Raycathode
Quote from: rickfriedrich on August 03, 2019, 02:49:32 AM
Chet!
Chet!
Why
are
you
leaving
so
many
spaces?
Are
you
drawing
attention
to
yourself?  8)
_____________
Quote from: ramset on August 02, 2019, 08:06:52 PM
Raymondo
I am not certain this is just one man's opinion
q
RaycathodeQuote
   I'm actually working on a device Jb style with a row or Neo magnets mounted on square steel section over a steel threaded section all north on one side and south on the other side but no slip rings used, instead I used 2 hall effect this gives a half circle magnetic effect that changes over every 180 deg. the circuit is a JB design that's supposed to recharge the battery. Unfortunately this design does not give any null point (dead zone) considering it's supposed to be an over unity generator ! It cant do both at the same time. I don't thing its funny !!
Raymondo End Quote
Raymondo
You see this problem you're having right now
Seems you purchased information or read information or whatever??
and assumed a result which you are not experiencing on the bench
And yes it's not funny
   Please be aware I did find a solution to this problem which I have not implemented yet as it's on a 'bread board' layout
   what it involves is to use one of the quad nand gates or a nor gates which involves a cap a resistor and a direction steering diode
   to shorten the on time or off time depending on the user of the gate in order to allow BEMF you have kick back time.. no doubt i will get round to building it on a
   pcb as It will need two sets one for each hall output and perhaps a red green LED to make it look good.
   Would you have preferred that you could have researched this information here at this forum where experimenters  have done
   the experiments and share the results openly for others to compare
   perhaps have learned not to waste your time there if that is indeed what you are saying I'm not certain?
   For clarity no such information is available anywhere to my knowledge
   That is to say such a database supported by a group of membership that is available if need be to engage .....or perhaps through
   representatives to engage (ask questions)?
   This is my dream for this venue
   and all these builders being helped by this community to do other experiments ...real science perhaps?
   in my opinion with all our resources and connections to universities scientists  EE,s  specialists in all fields and amazingly gifted
   builders worldwide
   Stephen has a tiger by the tail ..and can bring his mission statement to fruition.
   Here we have thousands of YouTube and other kinds of videos that need to be categorized
   Persons who have very good test equipment and show and share their results.
   With Complete transparency for discussion.... always
   In case something was missed ?
   What you witnessed here these last weeks were many of those same person's  and there need to be sure nothing was missed on
   their own benches
   Others are more confident perhaps much more experienced but always ask for enough detail to experience this claim
   themselves
   Here it is a system of checks and balances so no one person can take the stage and make a claim which holds no water , For or
   against a claim .
   If the forum has that kind of reputation  that is to say where nothing is dismissed without proof
   there is little concern for Hidden agendas of secrecy ....  or similar nonsense claims.
   Some  one will find a way if they are frightened of release themselves to get the information to others to investigate or try  or at
   least discuss .
   And that needs to happen in a venue where there are many men of like mind For checks and balances so that no one man once
   again holds all the information of the claim and it is  discussed within a group of like-minded individuals .
   Here I  emphasize an open source venue.
   Here we can build such a place and maximize our time and efforts
   And we have plenty of good builders with much experience to help vet claims
   As a community ...I feel and have always felt those builders need to be helped in some way
   So as to not carry so much burden themselves When they work for the benefit of all.
   There are a few things right now from these last few days that need a more thorough explanation
   You have to understand this will be a lot of work for Stephen ....to make a section where members teaching videos Are shared or
   discussed
   Perhaps someone has an algorithm which can input questions into a database of videos ??
   I am unaware of such , however I am certain it exists .
   Sorry for such a long post but we need to fix this and move forward .
q
'rickfriedrich' Please stay cool and explain, i'm not your enemy ??
of course if you so wished as you appear to moderate the moderator you could just
ask  Stefan for moderator control of your very own thread and halt all input accordingly.
I Just thought i would leave you with that thought.
Raymondo
Raycathode
Quote from: seychelles on August 03, 2019, 07:06:15 AM
SIDE VIEW
High have you got this to work, some guy (the guru to you)( a guy with a north german accent),  says he got slung off you tube
for publishing this, another guy who said he built it said it was difficult to get going and it needed
a driver and he got little return, but who really knows for sure,
Raymondo
