Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
Void
Hi Grum and Tinman. How are you guys making out with your test setups?
Anything new?
I have been running various general tests with battery pulsing and cap charging/discharging.
Nothing too Earth shattering to report back so far. ;D
If you are recycling energy back to the battery using cap discharges it should extend
run times, and I can see this from some of my own basic tests, but I have seen no signs of
anything I would consider very unusual or over unity yet.
All the best...
AlienGrey
Quote from: Void on December 02, 2017, 05:06:53 PM
Anything new?
All the best...
Is it that your just copying JB device for historic purposes ?
any one remember EM Junkie  Chris
See set of anti lenz cogging wound cols the magnet
cycles in between the 2 coils  if your interested.
Thought it might be of interest if not  pls ignore  many thanks
AG
Grumage
Anything new?
All the best...
Hello All.
I've been busy reinforcing the device and making a new commutator. I used a low viscosity Epoxy resin that has taken over three days to fully cure.
An old boss of mine kindly donated a brand new 10 AH LA motorcycle battery and another former employer gave me a new DMM.
If all goes well with the machining of the commutator today I hope to show you all our progress.
Cheers Graham.
stupify12
Anything new?
All the best...
About pulsing 12v set up coils. Try using 1uf -10uf 400-600v for the capacitor being charge, and connect a bulb to it. We found some result with the same set up on coil but different types of capacitor being charge. 12v power input. on 10,000uf 4v is the only charge we get. On a 4uf capacitor we get 400v which could light  a build if the pulse on the coils are continued. We found that when we charge e.g. 10,000uf or 4700uf the charge are being converted to lower voltage let say 4v, which eventually dies out  and can not sustain the system.  But with 1uf -10uf 400-600v with just 1 pulse bulb could be lit continuously as long u give it a pulse. With lower UF capacitor we get higher voltage, and the voltage can make the system sustain.
Will
wattsup
@Grumage
Good works as usual. About the commutator, I am sure you can find ready made slip ring sets that come with brushes that you can then re-drill the center to match your shaft diameter.
wattsup
