Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
a.king21
Itsu,The whole point is transmission and reception of electricity at resonance. You should have one transmitter coil and any number of resonantly tuned receiver coils.  Series tank resonance is most effective because you should see a voltage gain whilst the input amperage and circulating series tank amperage should remain the same.  That's the whole point of this exercise. It's two fingers at Kirchhoff's law .
At a certain distance from the transmitter the frequency remains stable. Then you can place an unlimited number of receiver coils  IN THREE DIMENSIONS and receive approximately 40% of the power per receiver according to the claim. The claim is superconductivity at room temperature at RESONANCE. At 18 volts into the gate driver the output voltage should increase 144 times whilst the amperage stays the same on both the input amperage  and amperage inside the series tank.
I am sure you know what this claim means.
You also need a gaussmeter in order to see the magnetic field in three dimensions.  The proper name is magnetic resonance and is the basis of Don Smith's work.
According to the claim most EE students assume that as  the voltage rises the amperage falls and that is where the big con exists. Do the experiment and find out  -  is the next big test of the claim.
The receiver coils should not be electrically connected to the transmitter coil in any way. They should be freestanding in the same way that a radio is not connected to the transmitter except by resonance ( ie tuning).
  You need some variable capacitors, and < 100 pf work in the 1.25 Mhz range.  If you go into the Khz you are gonna need bigger variable caps and they get very expensive.
You also need to experiment with grounding the receiver coils in the same way Tesla did.  What happens when you ground the receiver coils?  Another little surprise coming...
Suddenly Don Smith and Kapanadze seem credible.
a.king21
ITSU:  https://www.youtube.com/watch?v=BHr3eDELyHk&t=6499s  at 1 hour 44 minutes onwards is Don Smith showing the transmission/receiving device.  Rick's kit is minus the L2 coil and is safer than Don Smith's.
a.king21
Itsu:  Here is a screenshot of the device Rick has replicated.
itsu
Hi a.king21,
what you are describing is a total different setup as what Benfr has presented and what i am replicating.
I know all about the Don Smit fantasy circuits as when i started with this FE stuff about 10 years ago he
was the first one i stumbled on.
I spend months then understanding / replicating, but finally give up on it, with reason.
Anyway, the present Benfr setup does not work for me and i am awaiting for him to show his results.
Regards Itsu
