Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
benfr
Hi there !!!
Well, I'm impressed. I see Itsu's setup photo and telling that 's a dream come true. You are close to being able to replicate a Don Smith #2 "massive overunity" system. You have started to open the door. Congratulations !!
I also think that a.king21 has had such a creative and positive contribution to this thread. I suspect now that a.king21 has far more knowledge than I do !!
Itsu, you are stating to have worked on Don Smith systems and gave up. What a story ! I believe, now I have not yet gone so far, that if you get Rick Friedrich's book it will help you understand how you couldn't achieve discovery. Please BEWARE Don SMith system's are a "one hand in the pocket" machines, and that you should never touch any cable while in operation !
The power we are talking of right here are deadly. You would die instantly, even be vaporized. Don SMith 's systems are not a toy ! Rick Friedrich's RICK kit is safe. I would recommend to master it before building something bigger ! If you wish to stay alive of course ... ;)
Now I have 2 little 'mistakes' written and I need to correct it. The frequency is not 863KHZ with these capacitors. I have confused my reporting with an anterior experiment the same hour, please pardon me.
I will sum up again.
3 cap 100 pF
3 coil 157 uH
1 freq gen at the point of resonance as indicated in RICK 's kit : 1.25 MHZ (it is around that value, between 1.20 and 1.30, but you can dowse by 10 KHZ to find it quick-like. to find it you can position the bulb firsthand and then modify the frequency as indicated).
the positioning of the coil is also incorrect : I wrote to connect a 100 V bulb on x and y on the following series :
x- cap - inductor - cap - inductor - cap - inductor - y
but it is not correct. the one to use is :
freq gen cable A - capacitor -x - inductor - cap - inductor - capacitor -inductor - y - freq gen cable B
Sorry ! I was too hurried. But I believe what I'm bringing here will keep your faith.
The good news is while preparing my photo and noticing my 2 short mistakes*, I have noticed an even simpler and cheaper setup.
You can actually do this overunity setup with just 1 coil and 1 cap !!! :
cap - x - inductor - y.
(in tradeoff, you need to use 13 V instead of 11 V ).
An important statement to make as I see some of the measurements tried above involve oscilloscopes : you CANNOT use a OSCILLOSCOPE for it will CHANGE the resonance. (this is called a probe effect and it is well described in the kit ).
You must stick to real values things ie BULBS, LEDS that you know. The bulb you see is as stated a 100 V bulb that I bought in the USA.
Additional note : This test come also show overunity from a 1 V input to light 4 V LEDS : just replace the bulb with the LED, and drop the voltage down to 1 V.
IF YOU WANT TO SUPPORT OVERUNITY DISCLOSURE CONSIDER SPENDING 100 USD TO BUY Rick Friedrich's RICK KIT who has never hidden anything of his vast knowledge and genius to US ;D (I have no interest in the sales what so ever  ;))
Now the photos will speak ! One photo speaks 1000 words !
* short but enough to render impossible the voltage 700% overunity.
benfr
benfr
benfr
1 coil overunity Rick Friedrich's "RICK" kit
benfr
with 3 coils and a slight manipulation, I was able to light it from 8.7 V, too.
