Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
itsu
Hi Benfr,
as Gyula already mentioned, a NE-2 bulb only lights up with voltage applied at 75V and higher.
So it is not that hard to understand that a FG with 20Vpp is unable to light it up as we are 55V short.
If my FG was able to provide 100Vpp it would be able to light it up even without your 3-coil system.
So we need some device/circuit to increase the voltage to that 75V.
Your 3 coil system is able to boost up the voltage to do so, so is the mentioned joule thief etc.
No magic there.
But i see you are happy with what you have and that is good, enjoy it.
Also the readers of this thread are now aware of your ideas and solutions of free energy.
Regards Itsu
gyulasun
Hi forest,
When you convert say a low frequency input to high frequency by parametric pumping with the use of a varactor diode for instance, the voltage or current "amplification" takes places in resonant LC circuits but overall input to output power (or energy) ratio remains under 1.
I do not get how you connect this with "the room filled with electrostatic response from all metals",   how would you utilize "current flow outside of the wires"  when grounding the metals?
How do you think the input power needed to create the strong EM field compares to the power created by the current flow in your chosen load? Why would output be higher than input in this case I wonder (near field radiation or excitation).
You quoted Tesla tests on single wire power transfer: how it is connected to parametric amplifiers?  He was in the process of finding means to transfer energy first via a single wire where the 'second wire' was the total enviroment (capacitive bodies, 'devices') to make up for a closed circuit. He surely disturbed the local physical enviroment in the vicinity of the single wire but we do not know whether the enviroment gave back more than what he fed into the wire, and without measurements it would be just dreaming he received back more.
Also, unfortunately, none of the scientific papers which dealt with parametric oscillators/devices proves with measurements done on the built prototypes that output (power or energy) exceeded the input (power or energy) versus the input.
Here are the papers I mean: http://www.tuks.nl/pdf/Reference_Material/Mandelstam_Papalexi/  but there are more of course.
But all this should not discourage you, please continue doing tests as you desire.
Gyula
Quote from: forest on April 30, 2019, 02:07:01 AMMake resonant circuit with parametric pumping input frequency and the method of converting output to very high frequency. That way OU is real I think.
https://hackaday.com/2019/04/26/parametric-amplifiers-and-varactors/
I spotted this effect in 2005 with the room filled with electrostatic response from all metals. The proper grounding then makes current flow outside of the wires. In fact Tesla said it in plain sight in his interview. I believe Barbosa and Leal perfected Tesla method but we won't know due to cryptic patent text (like always).
"lamps" as indicators :
Voltage diminuation and power effect :
https://m.phys.org/news/2012-03-efficiency.html
1/2 Voltage means 1/4 power input but only 1/2 light power output diminuation : 200% gain performance
Eigen-/Spin frequency of the material
Also more for academical interests only , the performance result :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20041118&CC=WO&NR=2004100349A1&KC=A1#
how many lumen and heat output by 10/20/30 ...... identical lamp serie ?
Hello Gyula,
https://www.google.com/search?q=f.+braun+mandelstam&ie=utf-8&oe=utf-8&client=firefox-b-m
Question : which was https://de.m.wikipedia.org/wiki/Ferdinand_Braun his " energy scheme" ,
        whose accepted by Mandelstam ? + Papalexy:  parametric generator
Ate logo
OCWL
benfr
Quote from: gyulasun on April 30, 2019, 06:30:58 AM
Why I feel you are pulling our legs?
Gyula
This impression ceases when you stop looking elsewhere than where you are asked to. Ask itsu, he has the setup that you dare not build, so far has he also not been able to power his NE2 without my setup. :P
