Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
AlienGrey
Tinsel, if it's any help Donald Smith's original device he was selling, I've seen that device he was selling years ago the original 2 coils and an oscillator it was a Royer OSC assembly.
'Anyone' or his mate 'Someone' or 'Someone else' can make there own.  ;D ;D
AG
Vortex1
seaad asked:
QuoteVortex1 (all)
3) Does the the coupling factors or total energy transfer  be different  in this case maybe because we use a transmission (coupling) from
the coil part in a series resonance circuit (gen.)  to a parallel resonance circuit
  compared with (common radio)  parallel resonance circuit coupled to a parallel resonance circuit(s) ??
My guess is that they are equivalent
Regards Arne
You are correct, they are essentially equivalent. Because of the low output impedance of the signal generator current is basically injected into (by being in series with) the parallel resonant primary circuit.
In common radio tuning circuit, the parallel resonant circuit would provide an impedance match to the antenna and ground which uses to advantage the high impedance at resonance.
seaad
Instead of a gate gate driver it's possible to use an impedance transformer
I see some impedance mismatch at the secondary side too
see my suggestion
Regards Arne
itsu
Quote from: TinselKoala on May 02, 2019, 04:37:53 PM
Heh... at that frequency you are most probably operating in a pure EM mode, so you don't have to worry about "real HV". You may find that you can achieve "supernova mode" close coupling that does not result in a 1/r2 falloff with distance (to a certain limit.) Your receivers seem to be essentially the same as used in my system. The main difference is that I use coils of much lower inductance (and hence less power-wasting in ohmic resistance) and autoresonating drivers, in this case a Royer oscillator:
https://www.youtube.com/watch?v=9x2YfA9LU5s
Hi TK,
yes i remember your experiments and the supernova mode.
Did you ever find out for sure what it caused?  (filament resonance?).
Itsu
itsu
Quote from: seaad on May 03, 2019, 05:22:21 AM
see my suggestion
Regards Arne
Arne,    you draw a parallel circuit, but i am using a series resonance setup for both RX and TX.
Itsu
