Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
rickfriedrich
I decided to finally upload the video I mentioned yesterday that demonstrated what I've called the third stage process in the Loving Paths teaching. This is an example of DVD7. This is an example of technology and research not on internet forums (because they are useless). The same is true for Don Smith type systems all around the world.
https://youtu.be/6he58A5xTIQ`
The Zero AC or DC Voltage and Amperage (with reg volt meters)
Black Box Negative Resistance Resonance Transducer.
At The Renaissance Charge, LLC. Hollywood Florida Convention.
March 22, 2015
"It's not what is in the box but what is around the box!"
http://potentialtec.com/Box.jpg (shows first German demo) Notice wave.
This was one of my students from Germany who was one of the only ones to get what John Bedini and I were showing back in 2006 in DVD7. This is what I have been showing since 2005 in different ways, and in a basic way in many demonstrations with basic inductors and transformers. But this is the fully tuned impedance matching resonance model that can be multiplied out as much as possible. The rpm had to be just right to have the right frequency for it to be in resonance. I also had to start with the charging battery discharged below 11.8V and fully converted to a negative charge. 12V 12AH positively charged input battery started off charged and did not discharge for the full hour while over 100W loads were applied. I have shown since then my motors running at some meetings for two days like this even with the basic non resonant examples. But in this case you could multiply the output as many times as you want. However, the coils on the motor were all perfect and you cannot be out a centimeter when matching impedances.
This special video is the first time this was demonstrated in the US. We demonstrated this first in Hamburg Germany and England in 2014 as you see in the above picture link.
It is not easy to hear every word shared because people were talking, and because his English was limited. I do not agree with everything he teaches or necessarily with the words "zero point," "quantum," etc.
I have given everything you need to figure this out. I will only demonstrate in open box teaching the basic level of this technology as the specific parts and relationships are proprietary. If you pay attention to detail in what I have shared about Tesla then you can figure all this out easy enough.
popolibero
Hi Rick,
thanks for sharing this video, very interesting. There is something I'm trying to figure out. Let's say that out of the receivers in fig.5 or fig. 12 of the true wireless I choose a coil. In Tesla's example the coil is placed across the one wire transmission line (in parallel), without interrupting the one wire, which in my opinion means that the frequency has to be very high in order to get a node across these two connection points of the wire. Now, in dvd7 the inductor is inserted into the one wire, not in parallel, but in series, and the reason for that I suppose is to "slow down" or allow for a lower frequency to produce a node across the coil with the correct rate. So, in a sense in this case the coil is not the actual receiving device but replaces a piece of wire to allow for lower frequencies. The receiving device then would be the FWBR and cap. Am I seeing this correctly?
thanks,
Mario
NickZ
    Guys:
   I looked at that last video posted by Rick. Sorry but, that noisy thing lighting up a couple of little led bulbs, was not impressive, as it was offensively loud, instead.  I remember why I could never could fully view any of his posted videos before.
   I would not want something like that running in my house. I hope that he can show something better, and quiet.
Otherwise, solar panels would blow something like that away. Without any noise, easier to set up, and probably cheaper per watt output than what they are showing there. Sorry but I could not handle the noise, nor could view the whole video.
   Rick: We are not all idiots here. We already know about what we should or should not trust, in video or forum discussions, and don't really need you reminding us of the obvious. Even though you think that we do need your guidance on that, we don't.
  Then afterwards, you show us more videos to look at. But, say that the real deal will not be shown, as it's a secret, and proprietary.   Ok, I get it now...
baudirenergie
Hi NickZ,
Rick has shown what is in the box. Look at Loving Path Series (Zero Voltage Process).
It is to noisy..haha.. Where is a problem, to build a small box that dampen it. You can also do it with one Wire. All Informations about how to do you can find in this discussion.
What is the next problem? It is to big? it looks like not supercool? I can not believe it.
Quote from: NickZ on June 25, 2019, 10:53:23 AM
    Guys:
   I would not want something like that running in my house. I hope that he can show something better, and quite.
   Rick: We are not all idiots here. We already know about what we should or should not trust, in video or forum discussions, and don't really need you reminding up of the obvious. Even though you think that we do need your guidance on that, we don't.
NickZ
     Sorry, but that's it for me on this thread.     I don't need all the BS.    NickZ,  over and out
