Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 18 Guests are viewing this topic.
benfr
Quote from: a.king21 on June 30, 2019, 10:06:22 PM
Coils at all angles.  ha ha lol
So you have been able to light all the coils even at right angles (for instance 2 paralel tanks), well well done ! This is to me like the "environment conditioning and bringing overunities" that Rick talked about many times...noticeably in the kit...congrats, and thanks !
benfr
Quote from: Jeg on July 01, 2019, 12:49:38 AM
Hi all
I'd like to ask Rick about the series inductor impedances which serve as a stand alone reaction loops. Each connecting point between those inductances...Is that a point that we have to pay more attention like building for example reactive loops with specific lengths of wire harmonically related?
Thanks
Jeg
Interesting Jeg. I believe yes. The tesla impedance circuit/ said hairpin does it exactly if I'm correctly understanding it. Also mentionned by Rick.
Specific lengths shall create the harmonics, I believe too. Hence the concept of 1/4 wave length...which I'm working on also.
Is that an effect that relates to the amounts of the extracted free energy?
Thanks
Jeg
I would say yes. That's exactly how to extract the resonance amplified voltage / amperage to use it. The kit shows how to do that. For instance, the kit shows you how to extract the free energy to light a 95 V neon bulb from a mere 9 V input. (as the amperage stays the same; which the kit shows how to measure, too).
NickZ
Quote from: gyulasun on July 03, 2019, 02:02:38 PM
Hi Itsu,
You are welcome.
Small comment: maybe for achieving the sympathetic resonance you would need quite a few RX coils, perhaps you receive information on the approximate number of coils  for the phenomena to manifest.
If you do not have enough ferrite rods (or loopsticks from old AM pocket radios) for tuning the RX coils you could use toroidal cores just a single one (or stacked ones if their permeability is low) scavenged from discarded PC power supplies or any other 'gadget'.   Also, simple cylinder shaped ferrite tuning 'slugs' would also serve for fine tuning the coils.  You can wrap such cores up in foam or airbag material and put inside the bobbins for fixing them temporarily while tuning.
   Guys:
   Perhaps, it would help to space the coils evenly all the way around the main coil. As in winding turns on a torroid coil, which helps to fill the whole circumference. On small coils in the MHz range I've used pencils to help help tune the coils with. But, itsu's coil are much wider, so pencils may not work as well.
   Gyula:  If you don't watch out, you'll be in the ranks of a troll, like AG, and me.
   Itsu:     I think that I get the same stomach problems...        NickZ
itsu
Hi Itsu,
You are welcome.
Gyula
Gyula,
i have now 8 new coils, and will build another 2 to come to 10, which according to A.king21 is the minimum needed
amount of coils for the effect to manifest.
The ferrite won't be the problem,  i have enough like you mentioned, my problem is that they only tune 1 way, down,
so i don't see how they can be very usefull, but i will try to find out.
Together with an ifrared thermometer, gauss/emf meter and a ground wire at some specific points (??!!) we should
see some magic soon.
Itsu
itsu
Quote from: NickZ on July 03, 2019, 02:38:10 PM
Guys:
Hi Nick,
good idea,   like in this post (see video there)?
https://overunity.com/17491/confirmation-of-ou-devices-and-claims/msg535768/#msg535768
Itsu
