Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
tinman
Quote from: Void on November 11, 2017, 03:27:32 PM
If the caps were completely discharged every second (which they probably weren't if they were discharging into a battery),
and then fully recharged to 50V every second, it would work out to 56.25 Watts output to the batteries. If the capacitors were only being
partially discharged into the batteries every second, then the power output from the discharging caps would be less than 56.25 Watts.
The caps would only drop down to battery voltage at best,so they will never be fully discharged.
tinman
author=Grumage link=topic=17491.msg512951#msg512951 date=1510432935]
QuoteStarter motors really " pull the juice " way beyond 12 Kw....
Close to Grum.
To pull 12Kw,a 24v starter motor would have to be drawing 500 amps,which is very likely under full load at a 100% duty cycle.
But here we have the motor running at 2500RPM !apparently!,and at about a 25% duty cycle.
At 2500RPM,the motor would be producing a lot of BEMF,and so the current draw would be a lot lower--closer to say 50 amps.
So 50 x 24 is 1200 watts,at a duty cycle of around 25% = 300 watts.
QuoteGearing was also mentioned, looking at the picture everything is " in line " could the motor have had a built in epicyclic gearbox?
I also see no gearbox.
Brad
tinman
Quote from: norman6538 on November 11, 2017, 05:16:10 PM
However if you recall Naudin had a bingo fuel generator that looped - made gas that
ran the motor that ran the generator/welder that made the gas....
It behooves me that nobody picked up on the. To me its another lifter project of more
potential value.
Norman
As both the motor and hydrogen generator both run at high losses,i doubt it was a self runner.
Brad
tinman
So,is it going to be the Bedini energizer?
I have modified the below schematic to include the cap--would this be correct?
I have all the parts needed
The motor
The duel pole-duel throw relay,rated at 60 amp's.
A 38kg flywheel
4x high current 10 000Uf 63v caps
Magnets ?--any one know what type of magnets John used in his energizer,as he always seem'd to have a soft spot for ferrite ,but i have 19mm x 25mm neo's
Coils i can wind--any spec's on those,other than 250 turns each? What core material?.Wire size?.--are they hooked in series or parallel ?--guess we can sort that out when it's running,and set to achieve our 50 volt's at the caps.
Was there claims that this device is an OU device?
What was it's purpose?,as all i see is a motor drawing power from the source,and a generator returning power back to the source.
Brad
stupify12
Quote from: tinman on November 11, 2017, 07:58:43 PM
The motor
A 38kg flywheel
Brad
The proven OU device here is the FLYWHEEL, but nobody seems to check i posted above on this page.  We might need Buck-Boost converter on that HV capacitor being charge to convert it to pure amperage(12v or 24v) that can drive the motor when switch over. Chas Campbell was one of the example, so many have already uploaded the so called FLYWHEEL Free Energy Generator on the Youtube.
Will
