RobertDepelteau circuit
Started by RobertD, November 18, 2017, 11:41:08 PM
RobertD
Hello friends.
I just put this thing together, and wonder if anyone has comments.
RobertD
What you see is four (or twelve parallel) auto ignition coils. A spark plug, going into a high voltage primary through a diode, stepped back down to 12v, I would guess with a lot more amps than needed to drive this circuit, how much I can't tell you, but I think a lot. An arduino type of uC triggers the coils one after another, the more the better. The frequency is regulated by a microprocessor that can optimize for resonance. More coils allows higher frequency and more power.
I put #5 to show that more coils can be added.
Tesla said more power comes with high voltage and high frequency.
I think this can work. I have everything I need to build one with one coil.
I think this can drive a forklift motor.
A large step down transformer is needed so not quench any of the available power.
I'll make my own step down transformer to have an idea of what I need.
I'll use a MOT for trial. The 110 side because of the bigger wire, and use maybe 3-4 turns 3gauge wire for the output.
It will have to be rectified of course. And go through a golf cart driver circuit.
The stepped down voltage used is what you need for
the particular application, some forklift motors run on 36v.
Would need a separate coil for 12v.
My set up would be for the driver circuit to produce what is needed for constant speed driving, and to have a
supercap or battery bank for peak usage like acceleration or climbing. The circuit will charge the backup power during
low demand time, like city stop and go.
Robert Depelteau
RobertD
Hey guys, what's taking so long?
I posted it on Twitter already .
And other places.
RobertD
Thanks guys. Looking forward to see what comes of this.
visit my site: robertdepelteau.com
RobertD
Building the prototype, a couple of things I have to change. The MOT high voltage winding has to be the high voltage since the 110 side won't have enough reduction.  And I'll try without the diodes first.
