Thanks to ALL for your help!!
Win Nobel Prize by doing new double slit experiment
Started by isawit, November 19, 2017, 01:33:40 AM
isawit
I don't have the equips, but I know the theory is correct. Light is not particle nor wave in vacuum space. Light is electrons vibration force.
All light double slit experiments were done in the air, light travels in air/medium as wave form. If you do a new double slit experiment in a vacuum chamber, you can proof the old theory is wrong. You will find two light lines on the screen instead of interferentce.
set up like this
the light source/laser can be in the air, a square glass bottle, on the 2 parallel inside walls are the slits and the screen. connect the bottle to a vacuum pump.
show the light wave interference on the screen first, then pump the air out.
as the air pressure gets lower and lower, the light pattern on the screen should be changing.
until a hard vacuum, it should be only 2 bright lines left on the screen right behind the slits.
Please give it a shot, you may help improve science and win us some $.
isawit
a good way to prove quantum mechanic is total bs
start science revolution
i already told you why maxwell em theory is bs
there is no transverse wave carrier in vacuum space.
profitis
"until a hard vacuum, it should be only 2 bright lines
left on the screen right behind the slits."
Might appear as three if u wear sunglasses
isawit
Quote from: minnie on November 19, 2017, 05:55:06 AM
https://youtu.be/iphcyNWFD10
detected gravity wave from 1.3 billion years ago?
total bs. gravity and all forces are instantaneous.
forces are coexisting with matters at all the times.
